Evo Bore kit questions
I am new to HDs but have built a bunch of import bikes/motors, twins/4 cylinders...choppers/streetfighters... whatever I can get my hands on.
1. On a stock evo case how big of bore cylinders can I run? 3 5/8?
2. Whats a reasonable price to pay for case boring?
3. Does the case need to be completely stripped bare to be bored?
4. What are some good vendor reference sites for pistons, cylinders, cams etc.
5. How high of compression can I run on 92? 11.0:1?
The other alternative is the way I'm going. That is a Revolution Performance 85" big bore kit that is a direct bolt on. The compression ratio was set up specifically for my combination at no extra charge. I'm using ported SE heads, so the compression ratio on the pistons were dropped from the standard 10.5 to 9.5. This combination will work with the EV27 that you already have and that I am also running. I'll jetmy S&S Super E and set the Dyna 2000 ingintion for this setup as I have some competent help.
If this option might interest you, check out the RP website or call Andrew at 1-866-892-2109. He will be able to answer any questions that you may have and can work with you on your preferred combination. The kit BTW, has a lifetime warranty if installed as directed.
If I do go with an 85" RP would be where I shop though... seem to know there stuff and have a ready to go kit.
I'm pretty positive that 3 5/8" is the largest a factory case would go. You are then limited cubic inch wise by the lenghth of thecrankshaft throw selected.
Yes, the engine has to be torn down and the cases split to remove the flywheels. The case halves a reassembled and then the cylinder holes are bored. Aftermarket cases eliminate this problem, are strongerand can be had in sizes larger than 3 5/8". They are also clearanced for stroker flywheels. Your stock cases would have to be clearanced as well for some longer strokes.n
Far a prices to do the work on your cases, that varies by geography, the shop involved and perhaps shipping charges both ways.
You can check with S&S, Zippers, Delkron, Ultima, Recktechand others for parts vendor sources.
What are you going to do about head work?More cubes means more air and abigger cam will require bigger springs. All these factors including the compression ratio come into play when deciding on a combination. What kind of ignition are you using and will it have to be changed? If I had to change cams with my RP combination, I would look at the Woods W6 based onAndy's recommendation at RP. I might also look at the V-Thunder 3020 and 3030.I have a Dyna 2000 adjustable module on the shelf, so I have the ability to change the ignition curve and timing if needed.
Best advice I could pass along is to buy the best highest qualityparts you can. I will not run any parts in my engine or transmission unless they are made by a reputable US manufacturer. If you check and ask around, you will find that it is very difficult to get any kind of warranty out of Revtech. After checking around on prices, I decided to go with the RP kit as being the most cost effective for my needs, see I'm using stock 93 cases too [:@]!!
One of my RP cylindersarrived with a gouge in one of the polished fins. It was not shipping damage as the parts were packed very well. RP immediately offered to send me a replacement cylinder and pay the shipping both ways. How's that for customer service? Call Andy and he can answer more of your questions on the technical end.
I am looking for a big bore kit for my 93 fxr. It has an 80" now w/ ev-27 cam (probably going to change out for something a little larger), aftermarket ignition (can't remember at the time which one it came with from the previous owner). The carb on it was in definate need of a rebuild but I had a Weber DCOE 40 laying around from a previous bike that I will toss on it.
So in summary it is not wise to fit a big bore kit and the only way ahead to increase capacity is to fit a stroker kit, but even that has its possible problems. I have reluctantly given up all ideas of making further mods to my engine.
To answer your questions, you really need a 1994 or later engine to bore the factory cases out. The engine would need to be removed from the bike and stripped completely to bore it (as it will to fit a stroker kit). I have JIMS flywheels and am running around 10:1 compression ratio. You could consider after market cases? There are two options available: some will give you a 3 5/8 bore, others 313/16 bore. Sputhe even make cases and cylinders that will take a stroker crank and give you 104 inches, but the cost starts adding up. I havelooked down that route, but am now thinking of a new motor!
