Alternator plug oil leak
Old Mar 23, 2008 | 03:31 PM
michaelcoutts's Avatar
michaelcoutts
Stage I
Default Alternator plug oil leak
Hello, Oil is weeping out of the alternator plug on the crank case on my excellent 87 FLSTC Any easy ideas how to fix this please? Michael
Old Mar 23, 2008 | 04:52 PM
Mr1986FLST's Avatar
Mr1986FLST
Default RE: Alternator plug oil leak
Do you have a spring-type clip holding the connector from the regulatoron the outside of the case? If it is missing, that might cause it to weep. Mine is an '86 and I do not think I had it originally. The alternator & regulator was replace around '92 or93 and I believe the clip was added at that time.
Old Mar 23, 2008 | 11:49 PM
notlost_nc's Avatar
notlost_nc
It depends on your definition of "weeping". I find it easier to spray some Simple Green on the area occasionally, scrub with one of the kids toothbrushes and hose it off.
Old Mar 24, 2008 | 08:12 AM
dog155's Avatar
dog155
the only way it could leak there is if the connector is somehow sliding out of the case.
Old Mar 24, 2008 | 08:48 AM
Dr.Hess's Avatar
Dr.Hess
My 86 FLHT had the spring thingie from the factory.
If it bothers you, a little ultrablacksilicone on the outside plug would probably take care of it. It only has to come off if something Otherwise, (un-easy method) pull the primary, pull the inside plug and silicone that back in place. Or just live with it.
Old Mar 24, 2008 | 09:51 AM
sqdealgeorge's Avatar
sqdealgeorge
Are you running a quart of prim fluid in the primary? After 1989 the alt plugs came out of the case (easier to seal) That was a 32 amp system You could convert to this system your rotor can be re used just replace the stator and reg
Old Mar 25, 2008 | 02:48 PM
grbrown's Avatar
grbrown
I had this problem a few months ago on my 1990 FLHS, which I have owned from new. It was leaking wet oil, more than I was prepared to put up with! Therubber plug had deterioriated and would no longer seal properly, nor would sealant fix it, so I had the stator replaced in November (reduced rates at the dealer for off season Winter services!).
laserman2431
Jul 17, 2012 08:46 PM
brwdarr
EVO
Oct 3, 2009 06:26 PM
dgretz
Dec 5, 2008 06:21 PM
hoppypy50680
Sep 9, 2007 01:45 AM
nick03custom
Jan 14, 2007 11:15 PM
