I had a friend do the same thing on his 87. He tied to go go bad with the electronic ignition and had the same results as you. It ran like SH*T for some reason. He went back to points also.
I'm running Daytona Twin Tec. Like it alot has different sound idleing more agressive kindalike the twin cams. Smother not sure how much could be msd type spark control.
Does it use the mechanical advance or completely electronic?
Single fire?
How long have you run it (miles)?
My answer would be unless you found a killer deal on one, NO! If what you have is working good.....dont 'F' with it!!!!
You were just asking for opinions here, right?! My opinion is based on my personal experience with single fire...
