Oil pump
Old Apr 14, 2008 | 11:40 AM
bikerdad5's Avatar
bikerdad5
Default Oil pump
Has any one tried to increase oil psi by shimming the oil pump relief spring. And any tricks to get the cap loose, mine is siezed it seems.
Old Apr 14, 2008 | 12:48 PM
Dr.Hess's Avatar
Dr.Hess
Default RE: Oil pump
Some PB Blaster will help that stuck plug.
Why do you want to increase the oil pressure? Spec is something like 3-50PSI. If you want more than you have now, run thicker oil. Too much oil pressure robs HP and doesn't provide less wear.
Old Apr 15, 2008 | 07:14 PM
t150vej's Avatar
t150vej
DON'T DO IT!
All these "adjustable" pressure gadgets and heavier springs actually do is cause the oil flow to the crankcase to be starved at low RPM.
Oil goes to the valve train first, and when it gets enough pressure, THEN it starts going to the bottom end. Long as the lifters are rasttling, again, don't do it!
Old Apr 15, 2008 | 07:32 PM
tobyhd1's Avatar
tobyhd1
Check your catalogs.They have a spring that will give you a few more pounds.J&P part #740-526.$8.00 I`ve had one in my bike for years and I have more pressure all the time.Toby
Old Apr 15, 2008 | 07:37 PM
t150vej's Avatar
t150vej
I run 30w winter, 50w summer. I've had a "performance" spring in mine since I bought it, 80,000 miles ago until I switched to 20-50 one time. I had basically NO oil pressure. Went the the dealer and bought a stock spring and it came UP 7 pounds (same oil)
So again, replace the spring it you want, but use a stock one... Just my opinion based on my experience.
fxdyna99
Oil Archive (no new posts)
Oct 10, 2016 01:40 PM
scaley
Sep 20, 2012 04:55 AM
Klor
Jun 4, 2010 10:55 AM
jjb
Exhaust System Topics
Nov 21, 2006 05:02 PM
jjb
Nov 21, 2006 02:22 PM
