FXR owners (Turn Signal HELP???)
I've got turn signal problems on my 1991 FXRS. \\; I just installed new "harley" turn signals on the front of my bike. \\; They replaced a pair of aftermarket ones that had (2) wires.........(1-Red &\\; 1-Black). \\; The harley turn signals had a Black Wire (which I assumed was ground)...........a Purple Wire (which I assumed was the "hot" for turn signals.....................and a Blue Wire (which I assumed was for running lights). \\; I attached the "New Black Wire" to the "Old Black Wire". \\; I attached the "New Purple Wire" to the "Old Red Wire"...............and I just cut and taped the "New Blue Wire."
When I first start my bike up................the lights are constantly "on" (as running lights) and the turn signals work just fine. \\; Then after about a minute or so, the front bulbs go "out" and the rear turn signals stay on (but they get brighter and the turn signals don't work). \\; If I turn the bike off for a minute or so...............and then turn it back on...............everything works fine again............until a minute later.................and then the process repeats.
Is it possible that my bike is not meant to run front running lights.......................and the new ones being constantly "on" is overheating them?
My wiring diagram labels the stock lights as "Directional and Running Lamps."
The diagram shows (2) wires (both Black) running from the stock turn signals. \\; Only difference between the two is that one has "Silver Wire" and one has "Copper Wire."
Thanks for the help -
Mark
P.S. \\;\\\\\\; Here's a link to my post under electrical. \\;\\\\\\; You can see the wiring diagram here: \\;\\\\\\; \\;\\\\\\; https://www.hdforums.com/m_3469316/tm.htm
Second replace \\; your blinkers located in the headlight housing. That thing plays tricks.
Thanks a bunch -
Mark
 \\;The first day I bought my FXRS in 89 \\;I pulled the ignition switch and cut the jumper wire that keeps the lights on. When low on battery you will appreciate the ability to turn the lights off when trying to start the bike.
I'll be gettin' back to ya.
Mark
I checked my voltage on my left signal wires (1-black &\\; 1-red). \\; When I hooked up my meter with Black Volt Meter wire -to- Black T/S wire..................and Red -to- Red..............I got a negative reading.
When I hooked up my Black Volt Meter Wire -to- Red T/S wire...............and Red Volt Meter Wire -to- Black T/S wire.................I got a steady reading of 11V.
So................I thought that the original owner could have reversed the wires on accident................reversed polarity???
So I switched the wires leading to my NEW T/S. \\;
So then I had New Purple Wire -to- Black ...................and New Black Wire -to- Red.................New Blue wire still clipped.
Same thing happens. \\; They worked fine for a minute and then shut off.
So I then reinstalled my old turn signal (on the left side only) and tried it. \\; It worked fine and then shut off.............although I think that they stayed on quite a bit longer. \\; I'm thinking this is because the old T/S are only single filament and don't pull as much juice. \\;
I then reversed the wires on the Old T/S .......................so I had Black -to- Red .................and Red -to-black......................same thing happened.
Any thoughts?
P.S. \\; This was confusing to type................so I can only imagine how confusing it is to read!
Another thing I'm wondering is.............how can the new turn signals I put on the front be working as running lights if I have only connected the (2) wires (purple and black)???
The blue is supposed to be the running light wire.............and it is just cut short and taped?
I have a 'Badlands' turn signal module on the bike....................but I always assumed that it was a module that made the lights "self cancelling."
Any help is greatly appreciated.
Thanks -
Mark
