cylinder stud torque
Old Jul 9, 2008 | 02:42 PM
jokenroll's Avatar
jokenroll
Default cylinder stud torque
Does anybody know what is the torque for the new design cylinder studs (the ones with the shoulder down)?
I mean the studs themselves into the cases, not the head bolts...
Old Jul 10, 2008 | 07:39 AM
sqdealgeorge's Avatar
sqdealgeorge
Default RE: cylinder stud torque
&nbsp\\;once the shoulder bottoms out the torque setting is of no value I never used a torque value on these new style studs I'd inslall them and bottom them out&nbsp\\;
Old Jul 10, 2008 | 10:31 AM
classof96's Avatar
classof96
Can't remember,,,,, Service manual, priceless
Old Jul 10, 2008 | 12:18 PM
jokenroll's Avatar
jokenroll
ORIGINAL: classof96
Not really - there's some new stuff manual doesn't know about, like these studs for instance: they are of the new design and have the shoulder down. Thus, you can torque them, unlike the original shoulder-up design, so manual says nothing about it. If the manual knew friggin everything, we wouldn't have performance books and forums like this
Custom shop told me 12 ft-lbs - sounds reasonable ...
Old Jul 11, 2008 | 03:08 PM
FatGuyOnABike's Avatar
FatGuyOnABike
6th Gear
I&nbsp\\;recently installed the shouldered studs on my EVO, and installed the shoulders down (into the block). I just bottomed out the stud, and then gave it a good tug to tighten it.
&nbsp\\;
I was looking at the Clymer manual a few weeks later, and noticed that the diagram showed I should have installed the studs with the shoulder up. The mechanic at the HD dealer confirmed what I saw in the manual. Oh well, too late.
&nbsp\\;
I'm not sure why you would need to torque them, but I'll listen.
Old Jul 11, 2008 | 03:56 PM
jokenroll's Avatar
jokenroll
The original factory studs up to '96 I believe, were installed shoulder up.
Then the stud design was changed, so all the new studs (even the ones you get from HD) are installed shoulder down - they talk about it in the EVO rebuild video, they just don't say anything about torque.
Old Jul 15, 2008 | 10:42 AM
classof96's Avatar
classof96
test
Old Jul 15, 2008 | 10:45 AM
classof96's Avatar
classof96
Don't forget about using a ball bearing in the head nut when trying to get that torque, it works real well. Imagine, I learned that from a service manual, not a forum or custom shop and it worked
rhsmd1
2014-2024 Touring Models
24
Jan 23, 2025 11:49 AM
priceamp
Ironhead
Aug 12, 2014 10:09 PM
customsoftail200
Exhaust System Topics
Jan 26, 2010 12:59 PM
HDJIM1158
Dec 5, 2009 12:55 PM
indyjeff
Sep 30, 2007 09:52 PM
