High Way Crusingq
Old Jul 11, 2008 | 09:56 AM
Dr.Hess's Avatar
Dr.Hess
Default RE: High Way Crusingq
Then warm it up and do a high speed run at wide open throttle and kill the ignition with your kill switch while doing that, then coast to the side of the road and pull the spark plug and see what color the end is.
Old Jul 11, 2008 | 09:57 AM
Dr.Hess's Avatar
Dr.Hess
Of course, do this in a safe area. There are other possibilities more serious, but most problems like this are carb related.
Old Jul 11, 2008 | 10:31 AM
skullhead's Avatar
skullhead
What qualifies as a high speed run?&nbsp\\; Winding out 2nd or running 65/70 in 5th?
Old Jul 11, 2008 | 10:44 AM
Dr.Hess's Avatar
Dr.Hess
If your problem is at 70 in 5th, do that.&nbsp\\;
Old Jul 11, 2008 | 10:46 AM
skullhead's Avatar
skullhead
ORIGINAL: Dr.Hess
If your problem is at 70 in 5th, do that.&nbsp\\;\\\\\\;
OK, should make for an interesting maneuver!
Old Jul 11, 2008 | 12:03 PM
Dr.Hess's Avatar
Dr.Hess
Clean the carb out first and see if that fixes it.
Old Jul 11, 2008 | 01:45 PM
skullhead's Avatar
skullhead
ORIGINAL: Dr.Hess
Will Do!!
Old Jul 11, 2008 | 02:06 PM
pajoe's Avatar
pajoe
A fellow on another forum had his carb done by the fellow at the link below and he wrote that he now
gets 46 mpg 2 up towing a trailer, and has a lot of power using 87 octane and no pinging -
he said he does get an occasional cough out the carb, which many attribute to the lighter weight slide.
I may send mine to him but it will be a winter project.
http://www.harleydavcvcarbrebuild.com/
Old Jul 11, 2008 | 02:39 PM
skullhead's Avatar
skullhead
ORIGINAL: pajoe
Interesting, I'll keep that in mind.
Old Jul 11, 2008 | 06:27 PM
ToWhlRidr's Avatar
ToWhlRidr
I have a 96 Electra Glide Classic FI and it can cruise at 85mph on a good day.&nbsp\\; It has problems with long hills, but it livens up
once at the top of the hill.
