clutch cable replacement
Old Jul 31, 2008 | 05:00 PM
t150vej's Avatar
t150vej
Default clutch cable replacement
On a 5 speed do you have to remove the outer cover or can you work it all through the hole where the cable screws in?
Old Jul 31, 2008 | 06:15 PM
darylnj's Avatar
darylnj
Default RE: clutch cable replacement
you have to remove the cover
[IMG]local://upfiles/16467/EFA272AF91DE4AB0913C99B0CEFB9A48.jpg[/IMG]
Old Jul 31, 2008 | 07:45 PM
t150vej's Avatar
t150vej
My "book" doesn't say a word about it - least I didn't find it. Done a lot of engine work, just never had to get into the tranny side.
Thanks!
Old Aug 1, 2008 | 06:49 AM
dog155's Avatar
dog155
It is a little bit of a hassle with the exhaust and having to drain the trans fluid,other than that it is pretty straight forward.
Old Aug 1, 2008 | 08:59 AM
Calwoodbutcher's Avatar
Calwoodbutcher
Gots to pull the cover. Exhaust will probably be in the way as well. Not a big deal. Replace gaskets while you are at it.
Old Aug 1, 2008 | 11:11 AM
mtkawboy's Avatar
mtkawboy
Use a Harley cable if they have one. I used a Custom Chrome one because they didnt and had to run a die over the threads where it screws into the clutch cover because they were plated over. It s bitch to get started with the cable flopping and the angle it screws in. That was my experience anyway, yours may vary
Old Aug 1, 2008 | 01:22 PM
hotrod351's Avatar
hotrod351
it really not that bad of a job. just did it last week, installed a new cable and mrc easy clutch. back off the cable adjuster then i removed the rear pipe, drained the tranny oil and removed the tranny side cover. the rest is self explanatory. just make sure you fill it back up with oil.
justmealwatts
Mar 27, 2020 09:00 AM
Simmosofty
Dec 1, 2011 01:57 PM
NOLAcustomFATBOY
Jul 18, 2011 07:26 AM
~Bobtail~
Apr 29, 2007 11:38 AM
HDF Tech
Dec 27, 2005 09:13 PM
