Dogbone Riser Tighten Questions
Old Aug 3, 2008 | 10:07 AM
lowflyby's Avatar
lowflyby
Default Dogbone Riser Tighten Questions
How tight should they be?&nbsp\\; I can move the handlebars up and down about 1/2" if I push and pull pretty hard.&nbsp\\; I replaced the rubber bushings cause a few of them were cracked.&nbsp\\; I don't have any installation info and I can't find them on the web anywhere.&nbsp\\; Right now it's pretty smooth, I can actually see out of the rearview mirrors at highway speeds with the dogbones and lead buckshots in the handlebars.&nbsp\\; So tightening the nuts more could make it smoother or I can crack or split the rubber bushings.&nbsp\\;
&nbsp\\;
Appreciate any help.
Old Aug 4, 2008 | 05:13 PM
MCSarge's Avatar
MCSarge
Default RE: Dogbone Riser Tighten Questions
If your using the factory style rubber bushings there will be a little movement in the bars.&nbsp\\; If your talking about the handlebars moving in the riser you may need to shim the riser mount with a thin piece of rubber to tighten it up and provide more friction.&nbsp\\; Hope this helps.
doc308
Shovelhead
Nov 15, 2018 12:29 PM
wraplock
Jun 3, 2014 03:04 PM
rockets-21
Jul 23, 2012 11:41 AM
09heritagerider
Dec 5, 2009 10:22 PM
jaysonL
Dec 10, 2008 06:55 PM
