horse power
Old Aug 29, 2008 | 11:28 PM
hogcruzen's Avatar
hogcruzen
Default horse power
hello , can you tell me if 83 hp and 90 ft/t is good for an evo ? any info would be great .
Old Aug 29, 2008 | 11:52 PM
kbear's Avatar
kbear
Not bad depends on the Evo and what has been done to it.
Old Aug 30, 2008 | 02:09 AM
hogcruzen's Avatar
hogcruzen
the heads were worked over by sams performance , the cam is a bob wood w-6 , thunder header and weisco 10.5 pistons . is this run of the mill ? i think i will go with roller rockers and the wood w-9 590 lift cam this winter . i would like to know what other evo's are puting out . thanks to all .
Old Aug 30, 2008 | 09:37 AM
mjunk1's Avatar
mjunk1
Sounds a heck of a lot better than stock! I thought they only put out about 55hp stock, so to increase it by almost 30hp is a big difference. Sounds like a well chosen "suite" of mods.
Old Aug 30, 2008 | 10:05 AM
kbear's Avatar
kbear
Sounds a bit high but would depend a bit on your clearances and what was done to the heads as well ... not run of the mill for sure. Stock is pretty tame. The Thunder header depending on where you live may be a problem as it is pretty loud and not much in performance gain to some of the other choices (don't shoot). Pretty much did the same to mine, the Weisco choice was a good one for me, the Decker with the mods I did would pull the front end up and off if I gave it a good twist. I settled on the V&H as they were deeper rumble sound without the crack and still did make a difference in performance that was felt. Would also set off the beamer crowd car alarms if in town or a parking lot...Dyno'ed I was 79hp and 83 at the back wheel from a couple of free dyno's...For an 89 it was quick and fun. Good luck with it.
Old Aug 30, 2008 | 06:06 PM
hogcruzen's Avatar
hogcruzen
thanks guys .
Old Aug 30, 2008 | 06:08 PM
hogcruzen's Avatar
hogcruzen
i will try and post the dyno sheet so you can see .
Old Aug 30, 2008 | 07:45 PM
mtkawboy's Avatar
mtkawboy
A Softail chassis will dyno about 5-6 hp lower then a Dyna. A good operator can make a dyno read whatever he wants it to. You didnt mention the carb, thats a great number for a stock carb, too great.
Old Aug 30, 2008 | 07:58 PM
hogcruzen's Avatar
hogcruzen
i'm sorry , i have an s&s e . i know about the dynos . that is why i went to speeds performance plus . he is in alot of the good mags.
Old Aug 30, 2008 | 08:02 PM
hogcruzen's Avatar
hogcruzen
as far as the stock carb , i have seen a few bikes run 80 hp with a jet kit . bob wood can really work a cv over too but more than a jet kit with that .
