Compression test or leak down will tell you. You can usually hear it make a spitting noise. Usually Evos were bad about the base gasket leaking oil and it could be fixed by using a part called the oil fix.
Was compression test done at operating temperature? Op temp may be significantly lower. I always do a leakdown test after; you can pass a compression test but still have a leaky valve. Head gasket is fine at that PSI. The compression test opens and closes the valve (cranking) while the leakdown is at TDCC only.
Yes, I warmed the bike up to normal operating temp before doing the compression test. I was surprised that the compression was so high, given that anything over 90 lbs is satisfactory.
You wont be able to measure it, but you may be able to use your compression tester, if it has a quick connect for your air hose. Just listen and feel for a leak. It will give you an idea anyhow. Be aware though, that the air will push the cyl to BTC. If its in gear, the bike will move.
