mikuni, accel pump
Old Nov 23, 2008 | 04:39 AM
billyfish's Avatar
billyfish
2nd Gear
Default mikuni, accel pump
hi to you all, i run a mid 80s 1340 evo with a mikuni flatside carb, the bike runs sweet but starting from cold can be a pain. i suspect that the fuel accel pump isnt working can anyone confirm that with the air cleaner off and looking down the throat of the carb with the engine not running,should i actually be able to see petrol squirting from the accel pump nozzle? when i twist the throttle ?. because nothings happening ....once warm bike starts easy. choke is working ok. hope this makes sense your thoughts appreaciated cheers
Old Nov 23, 2008 | 07:25 AM
t150vej's Avatar
t150vej
Some carbs (mostly older auto) have a vacuum actuated accelerator pump, but not the case here. You should see fuel squirt. Here's the company instructions in pdf. form:
http://www.mikuni.com/pdf/hs40_manual.pdf
Old Nov 23, 2008 | 08:03 AM
billyfish's Avatar
billyfish
2nd Gear
thanks for reply and confirmation, thought you probably should see something but niceto have it confirmed, looks like it could be the problem, thanks for the link very usefull,, cheers
m1crazy
Sep 14, 2022 05:18 AM
Norm jr.
Carburetor Related
Apr 27, 2017 11:11 AM
black bart2
Oct 6, 2015 10:24 PM
warpathglide
Carburetor Related
Jul 1, 2015 01:36 PM
joedirt
Sep 19, 2005 10:06 AM
