Narrow belt
Old Feb 18, 2009 | 04:52 AM
HGM's Avatar
HGM
Originally Posted by schwangster
The 02-05 rear swingarm is identical to the 98 (and earlier) except for the rear brake mount. Width is the same.
Easy swap, but other ways to upgrade the rear brake, I suppose. Got mine on ebay for $40, so cheap and easy.
The swingarm, not me....
Excelent point, glad you mentioned it.. How different is the caliper mount? Will a >'00 mount fit an early swingarm at all? I've already changed the front, but noticed a difference in the pictures I've seen of early vs late mounts, and been hessitant to buy one. Maybe I'll change the swingarm too.. I like cheap and easy....
Old Feb 18, 2009 | 07:22 AM
schwangster's Avatar
schwangster
The brake mount on the new ones is a tab that interlocks with the brake, the old brake mount is a block the brake rests on. Could possibly weld the new style on, but black swingarms are available for cheap. Many have upgraded to chrome ones and the black stockers sit in the shop.
Or you could look at 4 piston brakes that fit the older swingarms. I know Jireh has some.
Newer swingarm on the right in pic.
Old Feb 18, 2009 | 09:20 AM
HGM's Avatar
HGM
Yea, thats what I was afraid of.. I'll keep my eyes open for a new swingarm..(used)
Thanks,
Old Feb 18, 2009 | 07:47 PM
schwangster
Ebay for a black one (take off)
or you may find a chrome one as NOS in a dealer,
now that there have been a few frame changes.
I posted a thread with pics of my swap on here.
Have to search for it if you need it.
Old Nov 5, 2009 | 06:34 AM
grbrown's Avatar
grbrown
I've just popped over from 'Peace and Quiet' and its great to see so many familiar faces!
I'm developing the idea of going to a narrower belt on my 1990 Glide. As a bit of background, I have all the parts ready to swap to a later swinging arm, which is my winter project. I am using an 07, with 1 inch wheel spindle and 9-spoke wheel, plus late 4-pot brake. Once I have trial fitted the bare new wheel I will need a new tyre and it is tempting to fit a 150/80 and throw caution to the wind! Problem is my current 140 tyre has only 3/16 inch clearance with the belt. I have removed the rubber curtain from the belt guard to get in the 140.
So if I go to the later narrower belt and pulleys (I prefer the idea of changing them all) will that naturally move the new belt away from the tyre and create more clearance?
Old Nov 5, 2009 | 08:48 AM
miacycles's Avatar
miacycles
The inner flange of the stock rear pulley is just swagged on. Take it to a competent machine shop and have them remove the ring, then turn the inside of the puuley, keeping the original profile until it is .060" wider thn the belt. Slip the ring on and re-swag it and you are set. The front pulley remains the same. Hope this helps. Buy the best belt money can buy when you go smaller, it will be money well spent !! Hope this helps.
Old Nov 5, 2009 | 04:41 PM
grbrown's Avatar
grbrown
Thumbs up
Many thanks John. I have since worked out I would have 1/20 inch clearance between my existing belt and a 150 tyre! That is based on measuring my bike with its 140 in place, and half the difference in the width of the two tyres.
Will a new narrow rear wheel pulley have an offset compared with my wide one, like you described modifying my present one?
Old Nov 6, 2009 | 03:18 PM
96 Wide Glide's Avatar
96 Wide Glide
John, when you say " turn it down", are you talking lathe ? I was thinking they would just put it on a milling machine.
Regardless, I've taken the leap of faith, and bid on a matching 1.5" Performance Machine pulley on ebay, for a fraction of the cost of P.M making me a 1 1/8". The backplate on the P.M pulleys, definately look like their attached with allen screws, so that should'nt be a problem.
The only thing I'm concerned with is, what effect this is going to have on alignment.
The flange where the pulley attaches to the wheel does'nt change, and the outer edge of the pulley remains where it would be for a 1.5" belt. I have no way of moving the outer ring of the pulley the 3/16" closer to the wheel, that the 1 1/8th pulley would be.
Guessing I'll have to do it with wheel spacing.
Old Nov 6, 2009 | 09:09 PM
miacycles's Avatar
miacycles
Originally Posted by HGM
I'm liking that idea... I'll have to look into it. Should be cheaper than getting another pulley too.. Also, I shouldnt have to do anything with the front sproket, right?
Thanks,
Correct, nothing needs to be done with the front pulley unless you want to change the ratio.
Old Nov 6, 2009 | 09:12 PM
miacycles's Avatar
miacycles
I have to wonder if I did this and took it down to a 1" belt, what size rear wheel and tire could I run?
also, anyone know the inner width of the 02 rear fender? I'll measure my 98 and post. Could be too narrow for a 160.
If you are making any kind of power and carrying a load the 1" belt will probably leave you sitting alongside the road somewhere. They are basically made for the show circuit. Now I know someone will say "I know a guy that is running one" Well he won't for long, don't ask me how I know!!
