cam clearance
Old Mar 22, 2009 | 05:23 PM
Scrubdog's Avatar
Scrubdog
4th Gear
Default cam clearance
Today I tried to install a new cam in my 87 evo. The new cam is a VThunder 5015(.585 ex lift), the old cam is unknown. But in the gear case the lobe closest to the bearing does not have enough clearance. Is this the case for all years? Am I limmited to what exausht lift I can run? I am think about grinding the case so that lobe will fit, has anyone tried this or think it will work?
Thanks guys
Old Mar 22, 2009 | 06:51 PM
miacycles's Avatar
miacycles
There is a relief tool made to cut clearance in the case. You can also do it with a die grinder. You need .060" minimum clearance. Don't forget to check piston,rocker box, lifter to lifter block, valve keeper to valve guide and valve to valve clearance. Hope this helps.
Old Mar 22, 2009 | 07:03 PM
1931jamesw's Avatar
1931jamesw
Its common to have to remove material on all evos when installing a cam with that much lift. Jims tools offers the tools to help. Also georges tools has something similar to jims for a little cheaper I think but dont know if the quality is as good as jims. As stated above a die grinder will also do. Hope this helps and good luck. Oh yeah, you may have to remove a little material on the underside of your rocker covers. Again, as stated above, check all your clearances.
Old Mar 22, 2009 | 07:14 PM
Hooter1's Avatar
Hooter1
I always use a die grinder.
psoff
Milwaukee Eight (M8)
Aug 25, 2018 03:44 PM
IRON1250
EVO
Jul 8, 2017 08:46 AM
Alienwulf
Engine Mechanical Topics
Jan 10, 2016 10:16 AM
omgtkk
EVO
Aug 28, 2010 02:57 AM
g_amey
Exhaust System Topics
Feb 8, 2006 04:17 AM
