bad ground?
Old May 8, 2009 | 08:17 PM
the_ogre25's Avatar
the_ogre25
Default bad ground?
I just got my bike (88 FLHS) back from paint today and got it put back together. the gas gauge and both fender tip lights do not work. I assume that this is a ground issue. My question is how do I ground these with out scratching off the new paint? Or should I just bight the bullet and clean a spot that wont be seen?
Old May 8, 2009 | 08:50 PM
miacycles's Avatar
miacycles
Pic a spot on the frame under the tank and run a ground wire to it.
Old May 8, 2009 | 10:00 PM
robertl's Avatar
robertl
Default ground
one of the main grounding bolts is below oil tank by your three relays.that area is all covered by oil tank cover. I belive tip lights front and back are grounded there already.
Old May 8, 2009 | 11:39 PM
the_ogre25's Avatar
the_ogre25
There is only one wire gong to the tip lights, its 12V to the frame. I think I have to clean some paint off the backside of the fenders.
Old May 9, 2009 | 06:15 AM
miacycles's Avatar
miacycles
Try a star washer under the bolt that holds the light on. They can usually bite through the paint and ground the light.
Old May 9, 2009 | 07:35 AM
the_ogre25's Avatar
the_ogre25
thanks for the idea!
Old May 9, 2009 | 04:43 PM
the_ogre25's Avatar
the_ogre25
I got everything working today.
ddsdoorguy
Feb 26, 2018 09:23 PM
falconbrother
EVO
Apr 16, 2015 08:01 PM
aces25
Sep 2, 2011 09:13 AM
forever young
Apr 27, 2009 07:29 AM
rmarion
Jun 14, 2006 12:08 AM
