cases
I used Hylomar on the last one I did, and thank god it was mine... I've had to use copper washers on 3 of the thru bolts (not fitment studs) to stop leaks
I've done dozens with silicone with no problems.I mean think about it: it washes out with hot oil... so you're trying to ensure a leak free seal on any minut imperfection in the case surfaces. If it doesn't squueze out, then it's somewhere that it is supposed to be sealing something, right? Well, if any hot oil washes it out from an imperfection - it will leak, and I will attest to that, first-hand.
And please do not think I'm trying to discredit John in any way. He does it for a living and knows his stuff. I just hobby at it but take great pride in my work, nonetheless. So John, I sincerely wish you luck on all the ones you've used it on. Splitting cases under warranty for a leak like that is very anti-profitable, I know.
However be sure to use a small amt,as you dont want it getting in oil passages or the oil pump.
I really never gave a thought to the possibility of different formulas by various manufacturers. It said right on the tube- "flange sealant" so who was I to question that? I used Permatex branded and clearly, there IS a difference between mfgs.
After all this, maybe I should go throw out my thread locking compounds by anyone other than genuine Loctite... and check the expiration dates on what's left
