Head Bolt Loose
Old Jun 17, 2009 | 09:19 AM
classof96's Avatar
classof96
Default Head Bolt Loose
I've got a '96, about 15k into a top end rebuild. The other day while riding along, the head bolt on the front cylinder, left side, forward of spark plug lossened up, so bad it sounded like the spark plug came out of the hole. The bolt would tighten but as soon as engine ran just a few minutes it would loosen again, it wouldn't stay tight until engine was shut down and cooled for a few. ( I was trying to limp to destination for help) I'm sure head gasket is shot, but not sure what is going on. I'm getting ready to tear down the front cylinder. When I did the top end I did install new push rods and studs from the company.
I'm just looking for opinions or idea's of what has happened. Thanks in advance, I can't get on everyday, but will asap.
Old Jun 17, 2009 | 11:11 AM
miacycles's Avatar
miacycles
Did you use any threadlocker on the bottom of the studs?? Check the installed height of the studs, and remove the one in question to check the threads in the block. Let us know what you find.
Old Jun 17, 2009 | 12:22 PM
hotrod351's Avatar
hotrod351
sounds like the stud is pulling itself out of the case, you might have to helicoil it. at least thats what happened to me on the front cylinder.
Old Jun 18, 2009 | 11:14 AM
classof96's Avatar
classof96
Ok, thanks guys. In my original post I meant to say new studs and head bolts, not push rods. My studs have the collar for set depth (nice) and had factory applied locktight, anyway, I'll take head and jug off in a day or so. I'll update.
Old Jun 19, 2009 | 06:15 AM
miacycles's Avatar
miacycles
Let us know what you find. when you put it back together make sure you have a good torque wrench and torque the head down in steps, 16, 20, 30, 36,42lbs, with a drop of oil on the threads and underside of the bolt. Let the head set overnight and retorque the last step to verify.
Old Jun 26, 2009 | 11:43 AM
classof96's Avatar
classof96
For those who asked, just an update. The head gasket was blown out around the stud between the chamber and the stud, the stud appears tight. I still have to check the head for warp.
owenewowen
Jan 25, 2019 03:29 PM
Panheader
EVO
23
Apr 23, 2016 09:11 AM
kino44
EVO
Jul 1, 2014 02:47 AM
jsbridgew
EVO
Apr 30, 2013 09:01 AM
NSCoyote
Jun 15, 2010 09:16 PM
