Volt meter drops 90 flhtcu
All the red wires that connect to the circuit breaker are hot. There is only 2 inches tops of them that are exposed. That 2 inches is hot.
The entire wiring system on my bike is stock. The red wires are all stock gauge.
I don't have any large radios or amps or lighting. Its a stock 1990 FLTHCU
Whether or not I have the spot lights or the high beam on, the red wires are hot when the bike is running.
Is that the main wire feeding the whole bike? If that us feeding the whole bike, which it kinda sounds like, they may be too small. Our electrical systems are a weak point. Don't get me started on the orange wire for the accessory circuit. So it is possible that the wire is just too small for the load. You don't have some kind of high power head light or super-performance ignition/coil, do you?
If you put an ammeter in series with the one wire leading from the main breaker under the seat, that should tell you the whole load, but it should handle full alternator output for your bike at least.
With the exception on the stator/regulator which terminates at the main breaker, every bit of "juice that runs thru the bike is connected where the two wires you mentioned are tied to that breaker. Cleaning that connection and/or replacing the ring terminals would be the first thing to do. And remember, it's "all" happening right there so it's normal for them to get warm and a bad connection anywhere could cause overheating and if the wires at the other breakers are normal temp, it'd have to be the main switch or a connection at it. But that's definitely the place to start and work out from there (toward main switch etc)
So.. this is what I am going to do:
Tonight I am going to swap out that wimpy red wire that runs from the 30 amp breaker in the rear to the 15 amp breaker in the front with a 10awg THHN/THWN/MTW 600v stranded wire and I am going to solder on some high quality ring terminals. That should take care of the heat build up at the ring terminal ends. Besides the heat.. the bikes electrical system seems to be fine now. I replaced or cleaned just about every hot and ground point.
DO NOT solder the terminals. I know this sounds contrary to what a lot of people will tell you, but the fact is a soldered connection will carry high voltage just fine but will not allow the wire/connection to carry the amperage as well as a crimped connection.
I'm not an engineer but ... Anyone who works with, or knows electricity will tell you finer stranded wire carries more amperage. The electrons travel thru each strand of a wire. The more strands, the more efficiently the electons can travel with less resistance. When you solder stranded wire you negate the up-side of the fine strands and effectively turn it into a solid piece of wire which cannot let the amperage flow as easily. It turns the terminal into a choke, in a manner of speaking.
Anyone who cares to dispute or correct me is certainly welcome because I can't reference where I read that, but think about it - you will never see a battery cable or welding cables engineered with soldered ends. So DO use heat shrink at the terminals to protect the strands from corrosion (may be all that's wrong with your existing wire) but don't waste time with solder unless working with single strand wire.
The reason some do not solder and crimp instead is because it is easier (faster and cheaper) _with very expensive professional tools and ends_ to get a high quality crimp connection than to get a good solder connection. Now, if you don't have the ultra high dollar crimpers (sized especially for your wire and connector) and the right connector, then it is easier to get a good connection with what you have and soldering, if you know how to solder properly. Also, in some extreme circumstances, a REALLY GOOD crimp connection may in fact be stronger than a really good solder connection. The connection itself may not be stronger, but there is some solder that wicks up the insulation, and that can make the area brittle.
Given our tools and skills, the best connection in my professional opinion (7 years Radio Electronics Officer in USMM), is to take the crimp terminal properly sized for the wire, crimp it on the wire, then solder it on after crimping.
They wouldn't let me into radio or medical school because of color deficient vision, but I get by ...
