Volt meter drops 90 flhtcu
Old Jun 8, 2012 | 09:07 AM
  #51
wtb3886's Avatar
wtb3886
Greetings George Williams
You said:
My Volt meter drops drastically when I use my turn signals.
You already know something is different from normal by noticing your volt meter dropping when your turn signals are used.
You have to determine what is the problem, (wire) (turn signal switch) (light)
You have a wire from your battery to your turn signal switch then it goes to your light.
Knowing your lamp comes on says your bulb is good but there is a problem with either the wire or the turn signal switch.
To determine which one is the problem you have to use a volt meter.
1st you need to know which one of the wires at the light is hot and which one is ground.
Use the volt meter and place the volt meter to measure dc volts.
Place the black volt meter lead on a good ground of your frame turn on your turn signal and take the red volt meter lead to one of the leads of your light, when you see dc volts you will know which one of your wires is the hot wire.
Now your ready to search for the problem.
Disconnect the battery hot (Red) cable and tape up your battery cable end and use a volt meter to test each wire to each light for resistance.
Place the black volt meter lead on a good frame ground and place the red volt meter lead on each wire going to each light
90 FLHTCU
When my turn signal is working it causes my volt meter to drop drastically
I don't have a flasher it is controlled through the module.
Does anyone have any ideas?
Old Jun 8, 2012 | 09:34 AM
  #52
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Ya'll do realize this is a 2 year old thread right?
torque pm me with an e-mail address and I will send you the info.
Old Sep 1, 2019 | 08:49 PM
  #53
Doug Peffer's Avatar
Doug Peffer
3rd Gear
I would like information on this work around please.
Old Sep 1, 2019 | 08:55 PM
  #54
Doug Peffer
3rd Gear
I would like info on adding the relay.
Old Sep 3, 2019 | 04:06 PM
  #55
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
This is a 9 year old post...
What issue are you experiencing that makes you think you need to add a relay?
What model and year bike?
Old Sep 3, 2019 | 06:16 PM
  #56
Doug Peffer
3rd Gear
1993 FLTCU 90th Anniversary model.
This has been getting progressively worse for years and I've suspected a voltage supply problem and heard of a work around by an old timer and this sounds like what he was describing as a remedy.
It started with not having enough power to run the sound system for a few years then the turn signal would work intermittently. The voltage meter would never read the true voltage in the battery and now won't even show 10 volts and the battery is always fully charged and starts with no problem. The turn signals, brake lights sound system and cruise control aren't being supplied with enough voltage to function.
Old Sep 3, 2019 | 06:17 PM
  #57
Doug Peffer
3rd Gear
The sound system will work in the accessory position on the switch. LOL
Old Sep 3, 2019 | 08:41 PM
  #58
Dan89FLSTC's Avatar
Dan89FLSTC
Is the sound system an OEM unit (factory wiring)?
It should not be too difficult to clear up the issues you describe, the 1993 model has a very simple electrical system.
Do you have a factory service manual, and a voltmeter (the one in the dash does not count as a voltmeter, it is just a doodad the factory put in the fairing to make the owner think he actually had a voltmeter) ?
Old Sep 5, 2019 | 07:36 PM
  #59
Doug Peffer
3rd Gear
Yes I have both
Old Sep 5, 2019 | 07:37 PM
  #60
Doug Peffer
3rd Gear
Yes it is the factory sound system.
