Volt meter drops 90 flhtcu
Old Sep 6, 2019 | 08:22 AM
  #61
86glider's Avatar
86glider
Check out the sticky on checking ur charging system at the top of the evo section,good place to start.
Old Sep 6, 2019 | 05:20 PM
  #62
Doug Peffer's Avatar
Doug Peffer
3rd Gear
The charging system was completely upgraded with a newer cycletronics hi amperage unit.
Old Sep 7, 2019 | 05:00 AM
  #63
t150vej's Avatar
t150vej
It'd be easy to get "into the weeds" on this but I'll offer a recent discovery that may be of help. I disturbed some wires while changing my speedometer recently and the results sound exactly like what you're experiencing. When I lost a good connection, my bike read 10 volts when everything is in perfect order otherwise. I cannot find some of what I'm about to describe in any parts or service manual wiring diagram but mine has what I believe to be grounds that read voltage when disconnected, so they definitely carry a big load.
Find the anti-dive valve for the front forks. It's probably near the left fork between the trees with a hose from the engine guard running to it. (I think they still used that arrangement in '90.) The valve will have 2 wires running into one end that actually operate it. Then look for wires terminating/junctioning on the body of that valve with un-insulated spade connectors. My color vision is bad but possibly brown on one terminal junction and red on a different terminal junction. The brown(s) may have 2 wires on each female connector. If you find something similar to what I described on your bike, clean those terminals and (or replace) the female connectors on the wires.
fredtman
EVO
Oct 29, 2017 10:27 AM
dulley
Mar 4, 2014 10:56 AM
kris0082
Jan 20, 2014 02:34 PM
jimbo285
EVO
Apr 3, 2013 06:18 PM
inthedirt
Jun 9, 2011 08:43 PM
