avon tires
GENERAL TIRE PRESSURE GUIDELINES AVON TYRES
Based on a 170 rider with no luggage
For 2 up or bigger loads increase accordingly
Venom Tires with reinforced construction
(130/90HB-16 140/90HB-16, etc.)
Solo 2 up light 2 up loaded
Front 38-40 40-41 42-43
Rear 44 46 48-50
Other Models Venom (not reinforced or radial),
Roadrunner, Roadrider, etc.
Solo 2 up light 2 up heavy
Front 34-38 40-42 42
Rear 38-40 40-42 42
General Size/Pressure Chart
Front Solo 2 up light 2 up heavy
80/90-3.25 32-34 32-34 34-36
100/80-3.50 32-34 34-35 35-36
110/70-120/90 34-36 36-38 36-38
130/60-150/80 34-36 36-38 38-40
Rear Solo 2 up light 2 up heavy
4.00-100/90 34-36 36-38 38-40
4.25-110/90 34-36 36-38 38-40
120/80-130/90 36-38 38-40 40-42
140/70-190/50 36-38 38-40 40-42
140/90-200/50 38-40 40-42 40-42
It's not as easy to parse in a post as the spacing formatting drops out so if you want the doc PM your email addy and I'll send it along.
Rear 44 46 48-50
Rear 38-40 40-42 42
Having owned Harleys since the '70s I find I always go back to them. We just did 2,500 miles fully laden an a fresh pair and barely touched them - with my S&S 107 doing its best to push us along and keep up with much younger bikes! I've never run them to their last breath, preferring to start a new riding season on fresh tyres, but expect to get at least 10k miles from this pair. The Best of Harley-Davidson for Lifelong Riders
for my fxds they recommend 36 and 40
when i talked to the tech and told him i rode 2 up he recommended 38 and 42
I find only adding a couple of psi when two-up is not enough. The bike feels as if the tyres are soft, so using the upper end of the permitted range gives better results and the bike handles much better.
