Speaker grill
Old Aug 24, 2009 | 05:02 AM
galtjunk's Avatar
galtjunk
Default Speaker grill
I need to recover the speaker grills on my 95 FLHT. Does anyone know how to get them off?
Old Aug 24, 2009 | 06:34 AM
miacycles's Avatar
miacycles
They are glued on. The safest way is to remove the outer fairing and work from the inside and outside at the same time. You can remove them from outside, but sometimes you can bend them. Heat from a hair dryer sometimes helps too. Be extra careful when you re-apply them as the glue has a tendency to bleed through. While you gave the outer off it is a good time to do some maintenance on the connections and grounds under there. Hope this helps.
Old Aug 24, 2009 | 07:32 AM
rivercityslim's Avatar
rivercityslim
Good advice. I wish someone had told me this before I glued mine.
SgtMic
Audio Systems
Jun 4, 2017 07:37 PM
Terminator69
Audio Systems
Apr 19, 2015 04:24 PM
flattracker60
Mar 23, 2012 07:50 PM
JeffSG
May 24, 2007 01:40 PM
Purp
May 11, 2007 10:03 PM
