how much idle oil pressure does an evo need?
Old Jul 8, 2024 | 05:51 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
Do you mean the guy who posted in this thread in 2009?
yep! I didn’t resurrect it, just read it from beginning like you’re supposed to!
Old Jul 8, 2024 | 06:42 PM
Max Headflow's Avatar
Max Headflow
BTW @Huckster 20 psi is fine at idle cold.. If 20 psi with hot oil, you got one heck of an oil pump or you are using 80 weight oil..
Old Jul 9, 2024 | 07:47 AM
Racepres's Avatar
Racepres
Very cold.. I would personally prefer Less than 20
Old Jul 9, 2024 | 10:29 AM
t150vej's Avatar
t150vej
The oil pump bypass is set to 20 psi. The light comes on at 5 psi.
The bypass can't dump enough off to compensate for cold temps and thick oil causes higher pressures.
Assuming correct (or reasonable) oil and warmer temps, a good pump will idle 12-15 and run 20psi.
The number 1 place of wear that causes low pressure is the tappet guides, especially the front.
JetRanger
Sep 22, 2023 08:34 AM
Ashnic
Milwaukee Eight (M8)
Sep 23, 2021 12:01 PM
Bluehighways
2014-2024 Touring Models
20
Apr 6, 2017 07:34 AM
jacknthebox
Jun 14, 2013 10:25 AM
mantodou
Oil Archive (no new posts)
Mar 12, 2008 07:05 AM
