front pulley questions
It's worse when cold and somewhat better when the bike is up to temp and the only check after riding I did was rocking in gear and heard the soft clank when the belt pulled it against the engine. Naturally I'll tear it down in the next few days and investigate further, just wanted some experienced opinions on the chances (or lack of) that I might save this one with proper torque and loctite.
PS, no leaks, knock on wood, so the pulley is the only issue.
Thanks guys....
Thanks Hess
As you know already, you won't really know until you get her apart. The newer style pulley has more spline thickness. With that being said, if the mainshaft is not worn too badly there might be enough extra spine in the newer style pulley to get the job done.
I have a new Baker 32T longlife on the shelf if it will help ya.
Now I understand why many "kits" include the seal and appropriate spacer - to allow for the extra hub width of the pulley splines. Learn something everyday.
Thanks Buddy, I'll keep that "spare part" in mind.
Tranny has had a noticable whine in 4th a long time, but not excessive and did get better with full syn gear oil after changing from semi-syn and have only gotten normal amounts of metal dust off the plug at changes.
It sounds like a rod knock when it does the noise, but not happening "when" a rod would normally knock/rattle. I'm kinda bluffed on that one. But maybe the harmonics of the belt vibration combined with loose bearings etc. is causing the rattle (and I hope that doesn't turns out to be wishful thinking)
The book gives zero endplay for the 5th gear and the mainshaft, each of which I have at least .015 endplay so reckon I'll get some "off the job" training and see what happens to the rattle/knock when I'm done with a rebuild.
I don't have any tranny experience on these and certainly welcome any helpful hints... guess it's time to shop for tranny tools
Thanks everybody
PS: I already changed the compensator washer, slider and gear. Rattle changed a little but wasn't the cause...
If you just need to change the bearings and seals it will cost about 170 bucks from the dealer. That price includes the springs on the shifter pawl, they definitely must be replaced.
I got most of my tranny tools from Georges Garage, good tools and they ship very fast.
You will also need a couple of snap ring pliers, and also a pair of internal expanding ring pliers for the rings that hold the gears on the shafts.
When you push the main drive gear out of the ball bearing keep in mind that the case on the far side of the bearing (inside) is a weak area and can fail, so don`t try to tap it out
These transmissions are very straight forward to work on, the hardest part of the job is removing the inner and outer primary covers
Don't forget to replace the shifter pawl while you're in there.
