Enclosed Chain Drive
Old Jun 28, 2012 | 07:50 AM
  #31
1984_FXRT's Avatar
1984_FXRT
Originally Posted by grbrown
That adjustment procedure must be published somewhere! It can't be a state secret. I have the 84-90 FSM and agree there is no useful info there.
I have ridden enclosed chain bikes of a different hue for donkey's years, but they have flexible tubes the chain runs through, which makes feeling the chain fairly easy.
As an aside, I came by a tin of graphite grease early in my ownership of those bikes and noticed that the only recommended use was for lubricating chains! So that is what I used exclusively for over 100k miles.
Apologies for the delayed reply - but, are you suggesting that the procedure to check the chain tension is to do so THROUGH the rubber sleeves enclosing the chain? The TFM really doesn't describe how to do this, and as you said, SOMEBODY's gotta know!
When I change my primary fluid tonight, I plan to drain the oil from the rear sprocket enclosure and pump it fulla grease. The PJ1 chain lube I use is just a spray-version white lithium, it works OK on dirtbike chains, so I figure it'll stay clean and stick to the chain just fine inside an enclosure.
Old Jun 28, 2012 | 08:43 AM
  #32
grbrown's Avatar
grbrown
All I am saying is that the only enclosed chain bikes I have owned (not Harleys) had flexible chain tubes and it was possible to check chain tension by pushing on the lower tube. It did require a little patience to get the knack! I haven't studied Harley's enclosed chain to see if that will work the same way.
I guess that any surplus of that lithium grease will bounce around inside the enclosure and lubricate the chain on the move, like my graphite grease did.
Old Jun 28, 2012 | 11:03 AM
  #33
1984_FXRT's Avatar
1984_FXRT
Thanks!
Old Jun 28, 2012 | 11:25 AM
  #34
irwinbiker's Avatar
irwinbiker
Default enclosed rear chain
Originally Posted by gnafin
Well i have a 1984 FLHTC and it has the Enclosed Chain Drive...well the only part left is just the sprocket housing....just want to know what you all have dont with this? keep it, remove it? go to belt??
i have a complete rear chain enclosed setup with good rubber boots if your interested send pm
Old Jun 29, 2012 | 06:16 PM
  #35
notlost_nc's Avatar
notlost_nc
Originally Posted by 1984_FXRT
How does one check the final drive adjustment and set it when ya can't see the chain!?!?!?
Thanks!
You need to squeeze the bottom boot in the middle and feel for the chain, raise it up and see how much play you have. It doesn't require much adjustment.
Fill the enclosure with gear lube until it comes out the bottom hole. I usually put the plug in and give it a few more squirts from the quart size bottle. Pretty much trouble free until you need a new tire
Sauraus
Jan 10, 2025 04:23 AM
VoiceofReason44
Sep 16, 2017 12:16 PM
bass3167
Jun 15, 2010 08:11 AM
jackinthebox
Feb 8, 2010 08:19 PM
HOTLAP
Apr 15, 2007 11:38 PM
