cam and carb
Old Dec 2, 2009 | 05:49 AM
caper's Avatar
caper
Originally Posted by panheadmatman
after much research the cam is the EV27, giving me a wide range of performance . now s&s super E or mikuni hsr42
Really no need to change carbs on an 80"er with an EV27...the CV is a very good carb and your set up isn't going to outflow what the CV can deliver.
The EV27 likes a bump in compression,but I wouldn't go over 10:1
Old Dec 2, 2009 | 10:30 PM
gsxrboy96's Avatar
gsxrboy96
i actually worked on a bike this year that had 9.75 to 1, and it had signs of detonation with the ev27, i would say error on the safe side and use only 9.5 to 1. and i couldnt agree more about the cv, its a awesome carb. chad.
Old Dec 12, 2009 | 12:41 PM
drjones's Avatar
drjones
I'd use the 2-7 and Mikuni too. Very good choices. PM me if you want to sell your CV. Also, Doug has a very good point about lifters. I've seen them go in as little as 32,000 miles, and as much as 49,000 miles. Change the cam bearing while your at it.
Old Dec 12, 2009 | 01:13 PM
96 FXD's Avatar
96 FXD
If you're going to run the EV-27, I wouldn't worry about bumping the compression. If you're going to purchase a carb, Mikuni, no question or comparison. However, on a mild cam only build your CV should be more than adequate, just get it dialed in, and spend the money you save on an SE ignition module, or an aftermarket ignition like Dyna or Ultima. When you do the cam, do the lifters, everytime.
Old Dec 12, 2009 | 01:29 PM
Hackd's Avatar
Hackd
If you run solo most/all the time the EV46 (or comparable) cam works good in the Softails Running two-up, then I'd go with the EV27 (or comparable) cam. Both are 'bolt in' cams. As mentioned check the lifters and I'd install a set of adjustable pushrods.
Stock CV carb + SE air cleaner kit. Get the bike dyno-tuned by someone that knows how to set up the CV, and you won't be disappointed.
I run the EV27/CV/SE filter/Dyna2000/Supertrapp slipons combo in my 93 FLHS and as other have replied: It runs like it SHOULD HAVE run from The MoCo.
Old Dec 12, 2009 | 02:00 PM
98 FLHX's Avatar
98 FLHX
Originally Posted by gsxrboy96
vthunder evl3020 with a stock keihin cv and a bob woods kt1 needle, the bike will feel like it should have from the factory.
Good advice right there....
Old Dec 12, 2009 | 02:39 PM
I8SMK4U's Avatar
I8SMK4U
Right now I have the stock cam, T-Header, an S&S carb. If I put the EV27 in, Should I upgrade the clutch? At What point do you do that?
Old Dec 12, 2009 | 05:44 PM
softail99custom's Avatar
softail99custom
Default cam
I just had an andrews ev46 cam installed with screaming eagle adj. pusrods, new torrington bearing, heavy breather air cleaner and v and h longshots and dyno jet kit on stock carb with dyno tune and i picked up 12 hp. at the wheel 67.49 hp 75.46 tq.
toxicstang99
May 31, 2012 09:02 PM
cruzinthecoast
EVO
Feb 14, 2012 02:26 PM
timberwolfz28
Feb 16, 2009 09:10 PM
XKROME
Apr 15, 2008 05:39 AM
ssls6
EVO
Feb 15, 2008 01:20 PM
