Apparently Hayden will only sell a 10 pack to a dealer, I only need two to do my Evo. I already have base gaskets in my James engine gasket kit so I don't really wanna pay $45.95 for another set of base gaskets and the 2 jets I need from Hayden.
There are other manufacturers out there that will do the same thing. I bought a set of 2 somewhere. I don't remember where, but if you look through a couple catalogs you should find some that will work. All they are is a tube that threads into the oil return hole in the bottom of the cylinder. Good luck.
