'96 Ultra Glide Classic backfiring issues....
Old Apr 6, 2010 | 01:40 PM
madmax4404's Avatar
madmax4404
Stage II
Default '96 Ultra Glide Classic backfiring issues....
I am having backfiring issues with my bike. It backfires when I let off of the throttle. I have had a compression test done and it was ok. I am kinda at a dead end as to what the problem may be. Anyone have similiar problems or know of a good solution?? Thanks in advance.
Old Apr 6, 2010 | 02:11 PM
EVOrider's Avatar
EVOrider
I had a crack at the Y-Pipe creating a pretty good exhaust leak. I would let off the throttle quickly and it would backfire. Repaired the exhaust and the backfiring went away...or at least I couldn't hear it anymore.
Is your bike EFI or carburetor? A few Glides had EFI at that time....and that old system was/is know to do funky stuff.
Old Apr 6, 2010 | 02:45 PM
madmax4404's Avatar
madmax4404
Stage II
My bike is an EFI. What kind of funky issues is it known for?
I did have a crack in my y-pipe but it was repaired (welded) back in late '08. Thanks for your help. I am gonna take it off and check this.
Old Apr 6, 2010 | 02:47 PM
terry rowland's Avatar
terry rowland
Default 96 ultra fuel injection
I have always had this problem. Eager to also find the answer.
Old Apr 6, 2010 | 04:38 PM
EVOrider's Avatar
EVOrider
The older EFI Magnetti Marelli definatley had its shortcomings....I've seen several backfiring issues due to the throttlebody. Check around the throttlebody for any intake leaks.....
If check engine light is on.....fix this first
I would start by cleaning the throttle body.....
Then make sure everything is adjusted properly.....cold/hot idle. Make sure the Idle Speed Control is working. A malfunctioned one can cause some really strange issues.
Rer-oute the crankcase breather so all the oil does not dump into the aircleaner.....for some reason, that itself cured many problems I use to have.
Anyways, check the throttle body really well.
Old Apr 14, 2010 | 12:34 AM
mkizer's Avatar
mkizer
mine did it all the time and would die when stopping, replced the heat sensor on the front head and all was cured!!
Old Apr 14, 2010 | 02:28 AM
V2Evo96's Avatar
V2Evo96
My 96 FLHT had decel pop below 2500rpm which turned out to be-- you guessed it--- crack at the Y pipe which on examination had been repaired before.
I nailed a complete system from an 02 model including heat shields, but excluding mufflers on Ebay USA for $60 USD-- cost me another $60 to get it here but well worth it.
Old Apr 18, 2010 | 11:36 AM
Idaho Scootertrash's Avatar
Idaho Scootertrash
My experience has been that a backfire on decell is usually an exhaust leak. As many others have stated, the "Y" tube is notorious for cracking. I put a fullsac true dual conversion on mine, eliminating the crossover completely and have no issues.
I also dumped my M&M EFI last year for Crane Hi-4 and a Super E.
Good luck!
Ultra_Rider
Dec 31, 2019 08:06 AM
Dynaman2020
May 16, 2018 10:55 AM
NeverEnough
Oct 21, 2013 08:51 PM
05Hog
Jul 4, 2011 09:09 AM
youngglide
Exhaust System Topics
Oct 1, 2010 08:58 PM
