2008 Ultra Classic questions about intermittent problems
Old Oct 7, 2013 | 09:51 PM
NeverEnough's Avatar
NeverEnough
4th Gear
Default 2008 Ultra Classic questions about intermittent problems
I've heard they have "intermittent" problems. Apparently a problem that shows up during riding that make the bike go into some type of "limp mode"? And I've heard some have had problems starting, maybe related to the other, I don't know.
What is the cause, and what seems to be the solution for these issues? Is it something to worry about even if the bike hasn't had a problem yet?
Old Oct 7, 2013 | 10:03 PM
nozzlehead's Avatar
nozzlehead
Yeah it's kinda like playing Russian ruelet.
It's happen 4 times on my 08 UC.
After 4 times being in the shop and 2 dealers, the last dealer found the problem. It was the plug behind the air filter on the throttle body.
It's been good now for about 6 months.
Old Oct 8, 2013 | 02:32 AM
mike5511's Avatar
mike5511
Never had a problem with my 08 Ultra......"knock on da wood"
Old Oct 8, 2013 | 05:04 AM
NeverEnough
4th Gear
nozzlehead- Throttle Body connector. Loose? Wet? Corroded? Broken?
Old Oct 8, 2013 | 06:02 AM
nozzlehead's Avatar
nozzlehead
It was loose. Wires looked like they had seen a rough time.
The first dealer I had it at said it was the throttle by wire system in the bars. Replaced it. Still no fix. Then took to another dealer, that is when the found the problem. Got new plug with new wire ends.
Been working good sence.
Old Oct 14, 2013 | 01:21 AM
mike5511's Avatar
mike5511
Good information to know. I will add it to the list in case it ever happens to me.
Old Oct 21, 2013 | 07:45 PM
NeverEnough
4th Gear
Anyone with this issue ever check the actual fuses? Perhaps corrosion there?
Old Oct 21, 2013 | 08:40 PM
Timpechos's Avatar
Timpechos
25 k in two years on my 08 UC with no problems.......
Old Oct 21, 2013 | 08:51 PM
Nute's Avatar
Nute
Well documented problem with Throttle by Wire. Read the follow Service Bulletin by HD. "TT418A: DTCs P2135 and P2101 Theory and
Diagnostics" This was published January 7, 2011. There is also quite a write-up in 09 Ultra Service Manual I believe if you look under codes for TPS failure. Search this forum "Limp Mode".
Permanent fix is new contact pins and dielectric grease in the connection.
roadisbill
Nov 26, 2014 05:45 AM
djaudette
Jun 8, 2012 01:33 PM
zapps
Sep 26, 2010 09:52 PM
pop1
Sep 22, 2008 08:18 PM
baddog1200c
Apr 24, 2008 08:28 PM
