Evo Miles
To answer the question specifically, the mechanic told me that you only have to reach up under the bike and feel the back side of the pulley for oil. It really doesn't take a lot of movement for the bike to begin leaking, as the pully/nut/lockplate is what holds the transmisson output shaft seal in place. Move the pulley out, even a few thou, and the seal will become ineffective.
The second time it happened was in Daytona, FL. I had parked the bike, and on my 'walk up' to it (I like to check for stuff that doesn't look right), I noticed another quarter size spot of oil under the primary. I knew exactly what it was, and rode the bike back to Kissimmee and had it fixed. That was back in 2002, and I haven't had it loosen again.
This is one of those 'come and go' issues, but it does need attention ASAP. And it isn't a job you want to do on the side of the road or in a parking lot out in BFE.
It's a pretty straight forward repair. However, you really will appreciate an impact wrench, because everything has to come off the left side of the bike. Like I said, you really don't want to do this on the side of the road.
Most of the repairs on these bikes are hand tool jobs, with an occassional 'special tool' specific to HD. If you've worked on ricers, you already know how to read a torque wrench...
http://www.britishironnwa.org/show2007.html
If you see one on a trailer, that was it.
I think we had a MGF at our show last year. The Seven in my pic is actually a Locost that I'm building from scratch. That was shortly after I painted it. I'm doing wiring and plumbing now. I'm in my 10th year on the build. Progress slowed after I bought the Esprit. I bought the Europa about 2 years ago. It is as they are found in the wild, that is, "Free Range Europa": Last ran 20 years ago, head in the boot, etc. It has to wait until the Locost is done, or at least on the road (are they ever done?)
1 - 40210-8SP Sprocket 'upgrade kit' $75.95
1 - 11147 O-Ring $3.95
1 - 34901-85 Gasket $14.95
1.5 quarts primary oil $6.38
1 pint trans oil $3.50
Total Parts $104.73
Shop 'supplies' $2.00
Labor (remember it's 1996) $85.50
Total Repair $203.76
Here's the parts list from Kissimmee Harley-Davidson to repair the leak a second time (10/21/2002):
1 - 11105 O-Ring $.28
1 - 11147A O-Ring $1.75
1 - 12052 Oil Seal $3.20
1 - 12053A Oil $5.65
1 - 31430-93 Thrust Washer $3.60
Total Parts $29.43
Supplies $5.00
Labor (3.5 hours) $210.00
Total Repar $244.42
Wow!! I bet that was your leak..... Maybe a new bolt will fix your leak...
