Jack Question
Old Apr 20, 2010 | 07:47 PM
Bruce in Montana's Avatar
Bruce in Montana
6th Gear
Default Jack Question
I've got a 95 FXD and, of course, it doesn't have a centerstand. So I bought an inexpensive motorcycle lift from Harbor Freight. Problem is...the oilpan sticks down about an inch from the frame. Would it be a bad thing to lift it by the oilpan?
Any suggestions are appreciated....thanks.
Old Apr 20, 2010 | 08:10 PM
Criio1's Avatar
Criio1
this is the engine casing, you dont have an oil pan, (unless there is a serious modification i do not know about)
it would be fine to lift it on the engine case.
Old Apr 20, 2010 | 08:16 PM
Charlie Bone's Avatar
Charlie Bone
The last time I worked on a friends Softail I filled the gap between the frame and jack with wood. Not a FXD but Softail rear shocks hang down below the frame as well, at least on his bike.
Old Apr 20, 2010 | 08:17 PM
Criio1's Avatar
Criio1
or you may be refering to the primary case, again this is okay to lift on too.
Old Apr 20, 2010 | 10:12 PM
1skrewsloose's Avatar
1skrewsloose
It may take some trys to get it right, but lift on the frame, blocks of wood, whatever, and multiple attemps to get the balance right, but I would not lift on any part other than the frame. my .02.
Old Apr 21, 2010 | 08:18 AM
Calwoodbutcher's Avatar
Calwoodbutcher
On a Dyna it is the oil pan. Like 1screwloose says use blocks on the frame. Make them just big enough for the jack to clear the pan. When I made my blocks I grooved them so the frame sits in the groove and they won't move. I used wood. They work well.
Old Apr 21, 2010 | 08:49 AM
Jim Kraft's Avatar
Jim Kraft
On my Softail jack, I cut the rubber pads out in the middle, cut them in to two pieces, and glued them on top of the end pieces that were left. That gave me plenty of clearance for the shocks.
Old Apr 21, 2010 | 08:52 AM
hotrod351's Avatar
hotrod351
i lift on the frame. if you want to know if you can lift on anything thats hanging down, well thats up to you, guess youll find out, but i would chance it.
Hey Man
Dec 4, 2015 09:45 AM
hiwaycruzer
Sep 22, 2015 04:00 PM
Kayakeur
EVO
Sep 5, 2015 11:51 PM
TheNameIs"B"
Mar 6, 2011 07:08 PM
Jaymac3772
Sep 12, 2010 07:51 PM
