adjustable PR got loose
Old May 21, 2010 | 08:52 PM
HGM's Avatar
HGM
Originally Posted by cosmo glider
I had a tick that I couldn't find until I put new tires on and inspected the front wheel bearings. I thought the tick was coming from the front head. Noticed a slight burn on the wheel bearing race. Replaced the bearings, of course, and the tick disappeared.
I appreciate the idea.. It still ticks when I'm not moving though...
Nice pic's on the rods. Mine didnt get quite that bad. I cought it before the end came out.. Clearly cracked and ready to come apart.. I was really surprised to find the SE pushrods at Harley to be as cheap as they were. I think they were about $110 and chrome molly.
Old May 21, 2010 | 10:12 PM
96roadking's Avatar
96roadking
Originally Posted by janne63
This is what You are waiting for with those RewTechs....Replace before they broke...
wow looks like it was a bit tight perhaps? what's all the damage on the bottom one from? almost looks like a vise grips was on it? Did you adjust them when the lifters were at their low point? did you let the lifters bleed down?
Old May 22, 2010 | 02:42 AM
janne63's Avatar
janne63
Yes,they were adjust correctly.The another rod is rear ext. and its way too thick.Now I have Bender Cycles CroMo rods and shortened tubes and did some grind inside tubes.No contact anymore.
Old May 22, 2010 | 12:14 PM
96roadking's Avatar
96roadking
Got it back together, made sure to tighten it and checked the others. Had a minor scare when I went to start it and it just spun before I realized that the plugs were still out! I gotta quit drinking the night before I work on the bike! While I waited for the lifter to bleed down, I went ahead and did the 3.00 true dual setup that t150vej mentioned in the exhaust part thread this week, only I used a piece of 1-1/2" conduit that was laying around the shop, so mine was free!
Pothole914
Mar 26, 2016 06:36 PM
ihjonny
Jul 7, 2013 12:12 AM
D1gger
EVO
34
Mar 6, 2013 06:45 PM
jokenroll
EVO
Jul 9, 2008 02:40 PM
mtnlvr
Exhaust System Topics
Apr 25, 2007 11:35 PM
