please help- 93 fatboy not starting
Old Jun 19, 2010 | 12:10 AM
208feist's Avatar
208feist
5th Gear
Default please help- 93 fatboy not starting
heres the deal- bike broke down(wouldnt start after stopping for lunch) two years ago and due to money and time i havent meesed with till now. i just put in a brand new hd battery and all i could get was a clicking noise to the silinoid located by the rear tire. i replaced that with a brand new on from hd same results. after that i removed the starter took it in to a local custom shop to test it- it tested bad. new one arrived today i installed it same story(clicking). i found on here you can jump the starter to the battery, if i do this it will engage just fine. what am i missing?? ive looked over and put a power meter to everything i can see or think of. any help would be greatly appreciated as im about to push it in to a lake.
Old Jun 19, 2010 | 12:41 AM
hatchetman's Avatar
hatchetman
Your not the first one with this problem. Some riders have a fail safe switch installed that bypasses the push button circuit. You have to rule out loose wiring, dirty connections etc. the wires that come off your start button are small so they are sent to a relay switch which can handle the heat of cranking amps. i would look for and test your relay switch because that is where it sounds like your power is being interrupted!
Old Jun 19, 2010 | 01:33 AM
208feist's Avatar
208feist
5th Gear
i noticed others with this issues, really frustrating. what relay switch shuld i be looking for? when i hit the factory starter button i get the cliking noise so to me anyways my starter button is working. ive looked over a lot of wires so far but sounds like i need to keep looking. any other ideas would be appreciated. thanks guys
Old Jun 19, 2010 | 07:55 AM
astark's Avatar
astark
I had the very same problem on my 98 and resolved with a starter relay, they look like this and are about ten bucks at any auto parts store.
Attached Thumbnails please help- 93 fatboy not starting-cat1-20item9-20harley-20starter-20relay-2030_40a.jpg
Old Jun 19, 2010 | 10:37 AM
208feist's Avatar
208feist
5th Gear
i bought a new starter relay from hD it still clicks. any way i may have gotten a bad one or broke this one?
Old Jun 20, 2010 | 11:55 AM
208feist's Avatar
208feist
5th Gear
update.. i went and bought another brand new relay put it in and still clicking. i was loking at the connection where the relay plugs in and noticed where the power lead came inti the harness and where it ran to the so i put a peice of wire (jump wire) between the rwo female slots, hit the starter button and low and behold she started. ran rough and sound like crap but thats a different concern. has any one tryed this or have any idea whats going on here. this is turning into a nightmare.
Old Jun 20, 2010 | 01:29 PM
IronButt62's Avatar
IronButt62
Trons is trons.
You may need change out the cables and evidently some of the wires as well. Sometimes old wire can break down underload. Gets corroded inside the insulation and will give a good continuity check when there is no voltage but as soon as volts are applied it opens up.
You can bypass everything in the system by running a jumper from the + terminal on the battery to the connection on the solenoid. If it starts (and it sounds like it will) then work your way back towards the switch. As soon as it doesn't start, you'll know the general location of the problem.
There's a reason why shops get big $$ doing electrical troubleshooting. It's a pain. But this should be a fairly easy and cheap fix.
Good luck.
Old Jun 20, 2010 | 06:49 PM
iceman0084's Avatar
iceman0084
just starter clicking or does it try to turn over sometimes?
Old Jun 20, 2010 | 11:58 PM
208feist's Avatar
208feist
5th Gear
thanks for the advice about the wiring being corroded, that makes sense and i should have thought about that. ill try running some new wire in the morning.
iceman--if i have the starter relay pluged in and i hit the ignition switch all i get is a clicking in the relay. if i unplug it and use a jump wire in the wiring harness i can get it to start. thats the confusing part to me, why it will work with a wire in there and not the relay--yes i have tried multiple new relays so im convinced its that the relay thats bad.
ill try some new wiring in the moring and hope its somewhere in there. thanks for the ideas and help i really appreciate it.
Old Jun 27, 2010 | 07:33 PM
goatkid's Avatar
goatkid
Stage II
I'm having a similar problem with my 94 fatboy, but mine won't crank jumping from the battery. Only cranks over if jumped to a larger (small car) battery. New starter, relay & battery.
Please let me know if you come up with anything
