Ignition System Recommendations
Old Jul 26, 2010 | 08:53 PM
ozzie65's Avatar
ozzie65
Well, I had a thought riding home this afternoon - check the timing. Somehow the timing was way off....
I had to advance it considerably, not sure how much exactly - had to do a static timing, way too much oil mist blowing out!
Runs like a greyhound now, back to her old self!
Need to pick up a clear timing hole cover to set it correctly, but for now she is golden
Old Jul 26, 2010 | 09:14 PM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
Glad to hear you fixed your problem! Nothing makes your day like a good runnin' Hog!
If you are still interested in an aftermarket ignition - I run a Daytona Twin Tec 1003 EV external module and a single fire coils, SE wires, and SE Platinum plugs on Bertha. I really like the Twin Tec. It has an adjustable rev limit in 100 RPM increments, single or dual fire modes, adjustable advance curves, and "multi-spark discharge" mode that fires the plugs multiple times at low RPMs to smooth out the idle and increase off-idle response. Don't know that MSD makes a ton of difference, though.
It also has other things you can tweak using their USB connector and their free software - like rear cylinder offset and the ability to program your own advance curves.
Old Jul 27, 2010 | 05:25 AM
BungoBill's Avatar
BungoBill
Great to hear you sorted it all out. Im sure I read somewhere that the Braided metal H.T.Leads shouldnt be used with some Ignition Kits. Anyone heard of this and any info as to why? Just curious! Bungo
Old Jul 27, 2010 | 06:58 AM
ozzie65's Avatar
ozzie65
Thanks for the feedback..
I have been leaning to this set up. Always nice to hear from a rider.
I think I will wait till after the August trip, I guess this will be my Winter project.
Old Jul 29, 2010 | 06:27 PM
ozzie65's Avatar
ozzie65
Unhappy Still playing up!
AAAAAGGGGHHH
I thought I had the problem licked..... but no
I only had about 30 miles and it started acting up again. So, I double checked the timing, and got it right on factory spec. I checked the VOES, and it test fine. I cleaned the ground on the VOES. Put it all back together and it ran great ........ this time I got 40 miles..
before the symptoms came back again.
Does anyone know if the stock ignition system can be tested?
My other option is to find an Indy to work on it
Or
I can throw some more money at it and replace the entire ignition system.
I am 99% sure it is electrical because of the intermittent nature, and secondly, on my way home this afternoon, the bike played up, then corrected itself. I then had to stop and pick up some groceries, then it wouldn't start.
Plenty of fuel (could smell it) No spark, I do have electric comp release and I can usually tell when it tries to fire.
I turned of the ignition, waited 30 seconds, turned it back on and it started on the first crank.
I know I am going to have to spend $$ either way, I just really struggle with the notion of paying someone else to wrench on my bike. (I have never done it!)
I would appreciate any ideas.....
Old Jul 29, 2010 | 07:13 PM
bagga's Avatar
bagga
if you know of anybody that has a bike try taking their coil off of their bike and try it on yours. ign. module too. it's cheapest way to do it.
Old Jul 29, 2010 | 09:04 PM
ozzie65's Avatar
ozzie65
I do have a spare coil, so I could try that, don't know anyone who has the same bike, so I am stuck there.
Let you know how I go....
Old Jul 29, 2010 | 09:22 PM
Dr.Hess's Avatar
Dr.Hess
What's your problem? Intermittent no spark? Check the wire under the cone between the pickup and the frame. Pull on it and see if it doesn't come apart on you. The wire breaks inside the insulation from all the motor vibration. Go through the book diagnostics on the ignition system. They are very thorough.
Old Jul 29, 2010 | 11:11 PM
Kabear's Avatar
Kabear
You did not fix the problem. The problem is the bolt that holds the timing thing(rotor) on is loose and allowing it to turn on the penion shaft.
Open the nose cone, remove the ignition module and tighten up the bolt. Make sure the rotor is timed to the shaft. There is an index tab.
Old Jul 30, 2010 | 08:10 AM
ozzie65's Avatar
ozzie65
That makes a lot of sense! It is almost as though the timing is changing!
I will check that after work today......
I have checked the wires per Dr Hess' suggestion, the loose rotor makes a lot of sense.
Here's hoping.
