Ignition System Recommendations
Old Jul 31, 2010 | 09:40 PM
  #31
ozzie65's Avatar
ozzie65
Originally Posted by ridemywg
I was getting intermittent engine shutting down and I changed all the breakers and never had another problem with shut down.
I replaced all the breakers late last year when I was having starter / battery issues, turned out I had a bad battery.
I am now at the stage that with the exceptions of the tins, frame and cases, this bike has been completely rebuilt.
Wouldn't have it any other way, I love the EVO and a Carburetor
With the work done to it now, it will last another 25 years !
Don't think there will be too many twinkies out there......
Old Aug 1, 2010 | 06:49 PM
  #32
ozzie65's Avatar
ozzie65
Just got back from a 220 mile run.
Problem solved!
Ran like a champ, 40mpg running at 70mph, 2-up
Ended up setting it on mode 7, curve 6
Bike has never run this good, obviously been acting up for a while.
One interesting note.... No issues with charging! I usually run (at the volt meter) 12V this time around, constant 13 -13.5V at the volt meter, up to 14 V with higher RPM.
Old Aug 1, 2010 | 07:16 PM
  #33
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
Problem solved!
YIPPEE! Glad to hear you solved your problem!
You'll love your Twin Tec. You can program custom advance curves if you like, but it probably won't be necessary. With your engine mods, you can play around with your own curve to your heart's content. To do that, you'll need Daytona's USB interface cable kit - which runs around $115 and fits all Daytona ignition systems. Seems pretty expensive for a cable, but it has a little box on it that probably contains some electronics. The PC software is free from their site.
I have mine set on setting 3 (street mode, single-fire, multispark, curve 5). Any more than that and Bertha will ping under 3000 RPM with the EVL-3010 cam she has.
Randall
Mar 1, 2023 02:59 PM
Poacher1967
Shovelhead
13
Sep 24, 2015 07:07 AM
jcsurf
EVO
Mar 13, 2015 02:54 PM
Scudda
EVO
Nov 27, 2012 02:11 PM
js124
Aug 10, 2007 02:10 PM
