New crack in case
Old Aug 27, 2010 | 07:40 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by sqdealgeorge
No this is not structural point It is strictly to hold the O'ring in position for a seal on the orig oil bath /chain primary
Very common, only problem it will cause is an oil leak...they even make a gasket so you can grind that part off, and replace the o-ring with a gasket.
http://www.jpcycles.com/product/430-...Ntk=All&Nao=40
Old Aug 27, 2010 | 07:59 PM
Tactical111's Avatar
Tactical111
Check the "fitment" tab. It only goes to 1984. Whew, thought I blew $850 on primary belt drive for nothing ( '91 FLHS) .
Old Aug 27, 2010 | 10:30 PM
Kabear's Avatar
Kabear
Just the 430-900 fits the '84 model.
The 434-192 Fits 1985-2006 Big Twin engines $29.95.
Old Aug 28, 2010 | 01:24 PM
Tactical111
Default Dough!!
I still like the new dry primary belt drive set up and no oil to leak or change now. The "dry" clutch with mesh derby cover is a little noisier with clutch disengaged but again; no messy oil or chain adjuster, compensating sprocket, etc. Jeez, wonder why my mechanic didn't know about this gasket change over fix? Maybe the gasket still leaks? I did have a 6" crack though the one on this thread looks real nasty too.
Old Aug 29, 2010 | 09:42 AM
cdrich's Avatar
cdrich
This might be the way to go for the short term. Thanks. I wonder if anyone on here has experience with this. I am still chasing down a leak in the rear of the primary that has eluded us for a year now. The only good thing about it is that this crack was found while looking for that leak, I wonder if anythig needs to be done to the crack after the lip is ground down.
Old Aug 29, 2010 | 02:55 PM
Tactical111
I've heard alot of good things about a product called "JB Weld"; kind of a "cold" metal repair and it's supposed to be as strong as a regular weld. Just an idea.
Clavinavi
Apr 7, 2018 08:11 AM
WilllyD
Jun 17, 2017 11:29 AM
APEDnLOW
Jun 5, 2012 09:14 AM
ezmo
Sep 19, 2011 12:14 PM
scotsport
Aug 10, 2008 08:21 AM
