clutch problem, I think
Old Sep 4, 2010 | 05:51 PM
vnvet68's Avatar
vnvet68
5th Gear
Default clutch problem, I think
Just picked an 88 flhp. Took it out for a drive and it started to loose drive. would not pull a hill. rpm's were going up, speed was going down. any help would be great. thanks
Old Sep 4, 2010 | 06:33 PM
sqdealgeorge's Avatar
sqdealgeorge
Good God another crazy Nam vet " welcome home " Sounds like clutches Get yourself a manual if needed Pop of the outer primary This should be an ABC clutch Time to replace the friction plates HD P/N 37975-84 There are 7 of these also inspect the inner clutch hub for cracks around the keyway taper I've seen at least 6 bad ones I was Army 2 corp engineers 68/69 Party on
Old Sep 4, 2010 | 09:57 PM
vnvet68's Avatar
vnvet68
5th Gear
Default clutch
crazy, probably, but glad I still wake up on the right side of the dirt.Thanks for the info and advice. Marines, Force Recon 65-66 I core, 3rd MarDiv hills around Khe Sanh 67-68. OOOORaaaaaH. Thanks for your service and welcome home.
Kebo
Oct 1, 2013 07:15 PM
Velocity1
Jul 28, 2013 08:35 AM
vnvet68
Sep 8, 2010 05:46 AM
GGW4Mike
Apr 25, 2010 07:53 PM
BGHV65
Nov 19, 2007 10:45 PM
