Annoying Chirp
Old Oct 6, 2010 | 09:07 PM
dz1087's Avatar
dz1087
I noticed this same type of chirp today on the 93. Gonna check the belt this weekend.
Old Feb 9, 2011 | 10:06 PM
PakMul's Avatar
PakMul
I vote for belt alignment on this one. At least it's by far the easiest to repair, rather than tear down the top end.....
Old Feb 10, 2011 | 05:47 AM
chopperNeil's Avatar
chopperNeil
My 92 FXRS used to chirp at exactly the same times as you say, was belt tension at the rear, cleaned it and re-tensioned and it went.
Old Feb 10, 2011 | 06:33 AM
elPrez's Avatar
elPrez
Originally Posted by Uncle G.
My bike will "chirp" like you describe if the belt is a bit loose. Check your belt adjustment before you do anything else. MY belt will chirp when chopping the throttle if it's loose, and squeal if it's too tight.
It's worse starting out on a cold morning, as the belt is looser when cold, and tends to tighten as the bike warms up.
Just recently dealt with this on my 05 Ultra
Old Feb 10, 2011 | 11:07 AM
Jim Kraft's Avatar
Jim Kraft
Someone one on this forum said when aligning the rear wheel, to adjust so that the belt runs in the middle of the rear pulley when turning the wheel forward. This instead of the manual that says to measure the swing arm to axle to align. This has worked well for me, and I have no noise issues with my belt.
Old Feb 10, 2011 | 03:48 PM
IronGear's Avatar
IronGear
You cannot align a vehicle by how the belt runs.
You need to follow the instructions of the people who designed and manufactured the motorcycle.
Belt noises are not addressed by misalignment, but can easily caused by it.
The rear pulley does not have a "centre" position for the belt to run, as it is size matched(as opposed to the front pulley) and is double flanged(again, as opposed to the front pulley).
A belt that is clean, correctly aligned on pulleys that are not overly worn, with the correct tension, will present no particular noise issue.
Old Feb 11, 2011 | 01:34 AM
1997bagger's Avatar
1997bagger
Amen!
Old Feb 11, 2011 | 05:18 PM
Jim Kraft's Avatar
Jim Kraft
My belt has about a 1/16" clearance on each side between the two flanges. After adjusting it this way I have measured the distance from the swing arm to axle on both sides, and it is within a 1/16". Works great for me.
Old Jul 28, 2011 | 06:23 PM
giobott's Avatar
giobott
Default chirps
I to went through all of sqeaky pipe solutions on my Road King. Then, with the pipes hot and wearing a pair of welding gloves I pulled and pushed on the cross over. Ah ha the squeak. While dismantling, discovered the pipe hanger mount, allan head bolts at the engine were loose. (damm stealer had their hands in there a month back) dressed the screws and torgued them down. Problem solved. No issues since, whew very anoying
Gunslingertom
EVO
32
May 18, 2021 09:30 AM
RedBeard_BassTard
14
Oct 20, 2015 02:47 PM
Scionic Wraith
May 23, 2011 11:07 AM
wild_ivan242
Apr 23, 2010 10:09 PM
marksfatboy
Jun 9, 2008 04:06 PM
