Light Intermittent Smoke
Old Sep 30, 2010 | 06:38 PM
Big Nate's Avatar
Big Nate
Stage IV
Default Light Intermittent Smoke
Well about three years ago I purchased a97 FLHt out of a barn for a good price, but it has been alot of work. For the latest about five months ago a couple of cylinder studs backed out of the back cylinder I had the problem fixed with the help of a local machine shop, and a friend helped put it back together. All appeared well until the other day, when after a short ride 25 miles or so I stopped and noticed intermittent light smoke out of the rear cylinder exhaust. Prior to the cylinder stud problem the motor was rebuilt, 30 over, 10:1 compression pistons, new heads (Stock), valves, lifters, pushrods the works, same Mikuni carb as when purchased and Samson true dual exhaust (straight pipes). 91,000 miles on the bike. I also appear to have a nickle to quarter size oil spot under the breather tube after a ride more so when it is hot. The smoke developes after the bike has warmed up. Any suggestions would be appreaciated.
Thanks, Big Nate
Old Sep 30, 2010 | 06:48 PM
Tactical111's Avatar
Tactical111
Default Nickels worth...
Thanks, Big Nate
Wouldn't worry about that little bit of breather oil esp. after a hard run. Blue smoke is oil burning could be a ring, valve guide, etc.? Good luck with it.
Old Oct 1, 2010 | 11:12 AM
Samson_info's Avatar
Samson_info
Former Sponsor
Tactical is right. it is a ring problem. if it were valve guides you would have smoke on deceleration. these are the two problems where oil is burned. a ring may have broken. make sure you have correct ring end gap in the cylinder before installing on the pistons.
JR
Old Oct 2, 2010 | 04:30 PM
SportsterBob's Avatar
SportsterBob
Remove your spark plugs and check the color...That is a good barometer for what is going on inside the cumbustion chamber...As a good measure, if one head/cylinder has an issue, it's best to do both....I learned that the hard way!!! lol
sweetspringer
Aug 14, 2017 09:09 AM
Bagger_Vance
Engine Mechanical Topics
87
Jun 6, 2015 03:24 PM
RicRides
Feb 9, 2015 12:09 PM
run_ride_hide
EVO
16
Oct 16, 2012 07:25 PM
jokenroll
Exhaust System Topics
Sep 25, 2008 11:10 AM
