changing final drive ratio
Old Nov 6, 2013 | 02:11 AM
Homeward Bound's Avatar
Homeward Bound
Originally Posted by grbrown
Fitting a 24T compensator and 37T clutch will change that to primary of 1.542 and overall of 3.131.
If you leave the clutch at 36T (that is an expensive part to buy), but change the compensator to 23T your primary would become 36/23 ...
A 22T compensator will give you primary of 36/22 = 1.636 and overall of 3.323 ...
At which sizes do you have to change the length of the chain?
Or rather ...
At which sizes do you *not* have to change the length of the chain?
I see 21T kits come with a chain from $100 (requiring a 36-tooth clutch shell ... is that not standard size?).
Old Nov 6, 2013 | 04:13 AM
Ken Oaff's Avatar
Ken Oaff
It is difficult to follow a thread when someone else interrupts the conversation.
Be considerate, start your own thread.
that is the nature of conversations on forums, threads do get hijacked from time to time
Old Nov 6, 2013 | 04:20 AM
grbrown's Avatar
grbrown
Wink
Hi HB! Chains come in lengths at increments of two teeth, so the stock chain will probably cover most popular compensators (crankshaft sprockets). The 21T SE kit I installed on my TC88 came with a shorter chain, but that is the smallest available. Baker has a chart to clarify the matter here.
Old Nov 6, 2013 | 05:24 AM
Homeward Bound
How much slack can the primary chain adjuster take up in people's experience?
Old Nov 6, 2013 | 02:54 PM
GraemeR's Avatar
GraemeR
Use this website if you want to see what effect different gearing ratios do to your ride. It has several Harley's preloaded but it's easy to update with your specific model specs.
Www.gearingcommander.com
I have used this site for years and it's normally spot on!
Old Nov 7, 2013 | 08:48 AM
grbrown's Avatar
grbrown
Wink
The difference between a 25T stock sprocket and a 22T! Quite a bit, IIRC some part of the tensioner can be reassembled to accommodate the extra slack of a smaller sprocket.
Old Nov 7, 2013 | 11:58 AM
Schex's Avatar
Schex
Check this out for chain and shoe fitment.
http://bakerdrivetrain.com/sprocket-and-chain-matrix
dvlgsxr20
Mar 14, 2014 07:10 PM
TTCHL
Apr 3, 2013 05:06 PM
maddyv
Jul 18, 2011 12:05 PM
rbabos
Oct 31, 2009 05:04 PM
VikingRider
Ironhead
Sep 27, 2008 08:36 AM
