Is there a way for me to do this
Old Oct 19, 2010 | 04:00 PM
SCHOONER's Avatar
SCHOONER
Question Is there a way for me to do this
Hi Guys (Still A Newbie)
Here what's happening and the advise I need.
My '85 Classic 1340cc Harley has been layed-up for the past 4yrs. or so.
Due to illness.
At the present time I've taken out the body parts off the bike; fairing, tour pak,front and rear fenders,etc,etc. I sanded it down with 400grit.
and now its almost got its first color on it and its starting to look really good.(see attachments please)
Now finally my question(s)
1. How can I TURN-OVER the motor manually ?
(engine is still on its frame)
2. Do I first have to put motor oil in the spark plug hole?
3. Now how in the world can I turn-over the motor
just to lube the cyclinders.
Any and all advise and suggestions will be GREATLY APPRECIATED.
Attached Thumbnails Is there a way for me to do this-saddle-bag-lid.jpg   Is there a way for me to do this-top-of-tour-pak.jpg
Old Oct 19, 2010 | 04:20 PM
SURFOR Chop's Avatar
SURFOR Chop
You could jack up the rear wheel and remove the spark plugs ... put it in 5th gear and rotate the rear wheel ... should turn over with a little effort (not too much) ....
Old Oct 19, 2010 | 04:28 PM
Dr.Hess's Avatar
Dr.Hess
4 years isn't that long, but I think some oil down the spark plug holes would be a good idea, then as SURFOF_Chop says, push it or turn the rear wheel in 5th gear and it will spin easy. The bottom end is probably full of oil anyway. Once you've moved it some, put a battery on it and crank. Wait for the oil to puke out the breather and have something there to catch it.
Old Oct 19, 2010 | 04:36 PM
grbrown's Avatar
grbrown
Its great to hear you are well enough to start work on your bike. The others have answered your question! Best of luck bringing your bike back to life.
Old Oct 19, 2010 | 05:09 PM
SCHOONER's Avatar
SCHOONER
Thumbs up HEY SURFOR chop
Hey Guy
Thanks for you impute and I will fellow you suggestions.
Old Oct 19, 2010 | 06:01 PM
sqdealgeorge's Avatar
sqdealgeorge
What happens in Vegas stays in Vegas Stick with us will get you running again
Old Oct 19, 2010 | 07:50 PM
SCHOONER's Avatar
SCHOONER
Thumbs up Hey Bro.
Hey Sqdealgeorge
Thanks for the incourgement. I need all the help
eye can get
A view of what me bike use to look like. Its in pieces now.All body parts are beginning to be painted in the coming weeks.
Old Oct 19, 2010 | 08:16 PM
Nubz's Avatar
Nubz
why not just pull the plug wires and crank the starter?
that is most likely what I would do with a car if this is bad someone tell me
Old Oct 19, 2010 | 08:17 PM
Dr.Hess's Avatar
Dr.Hess
Not a whole lot different from:
except for the dash, of course.
Old Oct 19, 2010 | 08:20 PM
Dr.Hess's Avatar
Dr.Hess
Nubz, you could probably get by with doing that. However, it is probably better to squirt some oil down the holes so that the rings have some oil on them when you crank it. Also, cranking it a bit without the plugs in puts less of a strain on all the bearings until the oil pressure comes up.
