Dieseling?
Old Oct 30, 2010 | 04:15 PM
dz1087's Avatar
dz1087
Default Dieseling?
Was putting around on the scooter yesterday and after about a 10 mile run, I pulled into a store and hit the kill switch. The bike shut down, then proceeded to give 2 or 3 more revolutions.
This has happened three times now. Anyone know what might be causing this?
Old Oct 30, 2010 | 04:22 PM
Faast Ed's Avatar
Faast Ed
Crappy fuel and carbon buildup are just two possibilities. I'd run some Seafoam thru there.
Old Oct 30, 2010 | 04:56 PM
BB4xl's Avatar
BB4xl
Funny my bike never does. The other day it did it once while out riding around. Hasn't done again. I know the change the gas from summer to winter around here. usually run Shell or Sunoco both 93 octane.
Old Oct 30, 2010 | 05:32 PM
Faast Ed's Avatar
Faast Ed
Definately run some good gad (if you are not already) before you start jumping thru hoops in troubleshooting. BP 93 is my fave, Shell is my second.
But if he's already into dieseliing, I'd bet he's got carbon built up from the oil breathers putting oil right into his Throttlebody. I always did think that was a poor setup from HD.
Old Nov 19, 2010 | 06:43 PM
dz1087's Avatar
dz1087
Could be the oil. Been blowing a bit out lately.
Hasn't done it since though, so maybe it was just a fluke.
Old Nov 20, 2010 | 07:34 AM
miacycles's Avatar
miacycles
Besides the above, check your idle speed, if it too high your engine will diesel. Possible causes are throttle cable too tight, throttle friction set too tight, or in need of lube holding the throttle slightly off of the stop. Air leak raising the idle RPM and also causing a slightly lean condition.
If you want to get the carbon out of the cylinders/heads an old trick it to ride the bike and get it good and warm. Then remove the air cleaner and take a spray bottle of water, start the engine, have a buddy hold it at about 2,500-3,000 RPM's and SLOWLY spray some water into the carb. The engine will bog down so between metering the amount of water and throttle setting you can keep it running. The water going into the hot cylinder will cool the carbon and it will flake off of the cylinder without doing any damage to the engine. I suggest changing the plugs after doing this as sometimes a flake of carbon can lodge between the center and ground electrode. If carbon is the culprit then it might be time to do a top end job as worn parts in that area can/will cause carbon build-up. Running way rich will also cause carbon build-up from unburnt fuel and accelerated ring wear(cylinder wash down).
In closing as stated by others Sea Foam is a terrific product too. Hope this helps!!!!
Old Nov 20, 2010 | 09:55 AM
joe28's Avatar
joe28
The CRAPPY gas lately will do a LOT of stupid stuff, so think of that first.
Try a different brand. Run that tank dry, leave the clutch out a tad to drag the engine when shutting it off til the bad Sheet is gone.
If'n you think you got carbon here's an Ol' time fix I've used a few times.
Get that bad boy HOT, run it til it;'s sweating!!
Take the air filter off, and keep gooseing the throttle while sparying a mist of water into the carb intake, (I use a old 409 spray bottle).
It'll cough, sputter and generally not like it.
The idea behind it, (they still use this on farm tractors)
The carbon get's hot and starts to glow red. This ignites the fuel and knock, rattle you got post ignition. Bad for yer motor.
The water hits the HOT carbon and it flakes off and out the exhaust it goes.
Ever take a motor that has blown a head gasket and sucked in coolant?? The piston is spotless.
Joe
Just an old guys ideas, should be taken with 2 beers!
Old Nov 20, 2010 | 03:25 PM
Dr.Hess's Avatar
Dr.Hess
The other "old tyme" way is to put a vacuum line in a bottle of water while the motor is running. You could disconnect the line going to the vacuum switch at the intake manifold and use that.
Old Oct 15, 2011 | 09:37 PM
dz1087's Avatar
dz1087
Well, it finally did it again since the first post in this thread. Only about the third time since the start of this thread. Anyway, I was wondering if anyone had any grief about running RESTORE engine treatment in the engine. I figure I have some low compression, oil consumption, and am going to need a rebuild in about 20k, so what do I have to lose by NOT running it at this point?
Old Oct 16, 2011 | 09:01 AM
grbrown's Avatar
grbrown
Some years ago I swapped bikes with a friend. Mine was a trusty and much loved bike, which he proceeded to thrash down the road on. Imagine my horror when, from a distance, I watched as my bike belched smoke and red burning particles out of the exhaust! Ran much better after that.
So the simplest and cheapest thing worth trying is a decent long ride, to get the bike up to operating temperature, then give it max rpm in the lower gears a few times, to see if it clears its throat!
