New cam! Nice!!!
Old Dec 12, 2010 | 07:24 AM
M&D88FXSTC's Avatar
M&D88FXSTC
Octane prevents fuel from pre-ignition. meaning the compression ignites the air fuel charge not the spark from the plug. on stock, 8-ish-1 compression, 87 octane fuel is sufficient. also a raise in octane on a stock engine will not give a raise in performance. as you raise compression the fuel wants to ignite b4 the plug fires causing the "ping" that can burn holes in pistons, damage bearings, rods, etc.On a high compression engine raising the fuel octane prevents this pre-ignition, or "ping", also allowing for timing advance for performance gains.
Any time you raise the stock compression ratio in an engine you need to run premium fuel, no ifs, ands, or buts....
Old Dec 13, 2010 | 12:17 AM
IronGear's Avatar
IronGear
There is some truth in areas of your post, but some not quite as accurate as it might be.
Just in general, octane is a rating system. It refers to the chemical structure of the fuel. Put simply, the tighter the bonds, the less likely they are to come apart. So you can exert more pressure on the fuel before it suffers degradation.
Pinging is not only caused by pre-ignition.
Raising compression does not necessarily mandate higher octane. Could not be more wrong. It may, but not necessarily so. There are many scenarios here. Timing, VE, spark plug set-up, for starters.
Remember, not knowing something does not mean it is not so. It merely means that you do not know.
Old Dec 15, 2010 | 05:08 PM
Plow64's Avatar
Plow64
Originally Posted by Piper54
Howdy,
Just installed a new EV27 cam in my 95 Ultra Glide. Not THAT tough of a job. VERY nice torque and ride. (not to mention the sound of her purring now) Sam.
Finished my EV27 install a couple weeks ago and am happy with the results so far. Piper, did you tweak the carb/ignition any after the EV27 install or are you riding the bike "as is"?
Old Dec 15, 2010 | 05:31 PM
M&D88FXSTC's Avatar
M&D88FXSTC
A : never said pinging was only caused by pre-ignition
B: as a pretty handy shade-tree mechanic i did substantial reading to substantiate my post &....your right, you dont need to raise the octane rating in the fuel when compression is raised....however, it seems that either extensive head work, timing retard, higher revs, enriching the fuel mixture, or a host of other things need to take place to prevent this from happening (several hindering performance, fuel economy & negate the use of higher compression pistons to begin with in my opinion) so it would seem that a good rule of thumb would be...if u raise the compression of a stock engine to ohhh say...10:1 it would be a very good idea AND cheap insurance to run premium fuel. If you still experience ping, knock, pre-ignition or whatever u wanna call it, you may want to venture further.
C: I was only trying to help someone
Old Dec 16, 2010 | 06:14 PM
redrott's Avatar
redrott
Put a ev-27 in mine and wish I never did valve noise is terrible there is more power but not enough to make the noise worth it
Old Dec 16, 2010 | 07:25 PM
Jim Kraft's Avatar
Jim Kraft
I guess the thing to remember is that raising the octane slows the burn rate. That helps when raising compression normally.
Old Dec 17, 2010 | 04:09 AM
IronGear's Avatar
IronGear
A. Yes, you did, albeit quite possibly inadvertently. And for the record, "octane" is not an object, so it cannot stop anything from anything. It is a rating.
B. It was already clear that your post is merely internet research, and no actual experience. And I really do not need you to tell me I am right.
C, Then offer advice from proven experience only, not from web browsing.
Old Dec 17, 2010 | 08:00 AM
miacycles's Avatar
miacycles
C, Then offer advice from proven experience only, not from web browsing.[/QUOTE]
Iron geaar, Seeing as you brought this subject up, why don't you post your resume. That way all will know your "experience"?????
Old Dec 17, 2010 | 03:21 PM
fxstcguy98's Avatar
fxstcguy98
I rode mine for a year or two before I put in the EV-27 and didn't notice any change in the valve train noise. Did you use the correct shim on the camshaft? Did you check the proper mesh between the cam gear and the pinion gear? You can either press your old cam gear onto the new cam or get a different pinion gear (they make several different ones). You may also have an adjustable pushrod hitting the pushrod tube making noise. I would investigate and find the noise.
I'ts a great cam for my bike, with a S&S super E and a SE ignition module, I have eliminated all the coughing and spitting it used to do and it runs strong. No pinging either but I run 89 to 91 octain.
Old Dec 19, 2010 | 09:43 AM
Piper54's Avatar
Piper54
I had actually rejetted the carb a month or so ago and installed a big sucker kit.
It makes a huge difference.
Turret_plug
EVO
50
May 31, 2016 11:41 AM
MILLER41143
Oct 27, 2011 04:42 PM
SURFOR Chop
Aug 19, 2010 10:47 PM
duranbayarea
Nov 8, 2009 09:38 PM
ROADRAGE98
Exhaust System Topics
Feb 23, 2006 08:13 PM
