eBay stator kit ?
Old Dec 19, 2010 | 04:42 PM
Doug S's Avatar
Doug S
I think it's reasonalble to see a number of failures considering that the newest of our bikes is atleast 10 years old. The OP bike is a 91 and if this is the first stator he is replacing then I would definately use OEM because it lasted 19 years. Besides, I consider these parts to be mission critical and would use the best I can afford and wait until I could.
D
Old Dec 19, 2010 | 06:23 PM
BB4xl's Avatar
BB4xl
I agree with Doug S. Most of the Stator problems are on older bikes, mine included. My HD Stator lasted 18 years and 50,000 miles or so. Thats on a bagger with radio and lights. The only reason I replaced the stock one was to upgrade to a 32 amp. Which is the one I just replaced last summer after the 18 years. I just replaced the stator with a HD OEM one. the Rotor was fine.
Old Dec 19, 2010 | 06:58 PM
MDodson's Avatar
MDodson
I only need a regulator right now but the plug is half pulled out on the inner primary. If I had to take it that far apart to fit the plug I was going to change it all and the leaks on the primary also.
Old Dec 19, 2010 | 11:42 PM
BB4xl's Avatar
BB4xl
MDodson Actually when my Stator went, it was the wires going to the plug that shorted out. They wore thru rubbing inside the primary. They were still mounted right but just wore thru from vibration. I asked a local Indy shop owner and he told me that he has seen that a lot. You might want to look at your wires. At first mine started over charging. Then it just went.
timd315
EVO
May 26, 2016 03:57 PM
Son of PMS
EVO
19
Oct 26, 2015 10:46 AM
Bullys FLSTN
EVO
20
May 10, 2012 06:46 PM
svkidd
Engine Mechanical Topics
Mar 11, 2011 06:22 PM
svkidd
Feb 18, 2011 02:56 PM
