breather tube
Old Dec 28, 2010 | 02:04 PM
irydasteelhorse's Avatar
irydasteelhorse
Default breather tube
i have a new-to-me 89 FLHTC, bone stock other than exhaust. it has the lil breather tube attached to the air cleaner, and ive seen others that have disconnected that line. if i were to do that to clean things up, should it be left open, or have a filter put on it? upright, or down? whats the best thing to do for my motor?
thanks
Irydasteelhorse
Old Dec 28, 2010 | 04:33 PM
miacycles's Avatar
miacycles
Put a breather on it, you can also run a hose up under the seat and put the breather up there too.
Old Dec 29, 2010 | 02:14 AM
Holster Maker's Avatar
Holster Maker
Just run some 5/16th" fuel line down to a breather w/bracket. Look at my bike, 9" below the air cleaner's 7 o'clock postion is a round chrome breather attached to the tranny bolt. I came off both heads to a T fitting and then ran down to a breather from J&P.
You could go down into the exhaust with a draft-tube for some HP.
Really helps my race cars. Vacuum seals the motor (rings) and less pressure for HP.....
Old Dec 29, 2010 | 10:15 AM
RidemyEVO's Avatar
RidemyEVO
I put the hose down to the chrome breather, it works well but does drip once in a while. You can see it below the pipe and in front of the rear foot board.
Old Jan 9, 2011 | 05:04 PM
89 TA's Avatar
89 TA
I got mine in the same location as holster maker.
ThePaintPirate
Feb 9, 2018 06:09 AM
paco12
Sep 25, 2017 07:45 PM
Mchad
Sep 1, 2017 09:18 PM
flhxmc
Exhaust System Topics
Sep 5, 2013 07:13 PM
impala
Jan 28, 2008 02:25 PM
