Horn issue
Old Jan 28, 2011 | 06:38 PM
harleylay's Avatar
harleylay
Default Horn issue
I have an 95 softail cant get my horn to work hasnt worked since i got the bike. I thought horn was bad until i checked it off the battery. It has a red wire running to it. Is there something im not seeing or my switch bad if so any other options. Thanks
Old Jan 28, 2011 | 06:51 PM
96roadking's Avatar
96roadking
Is your horn grounded? If it doesn't have a ground wire going to it, it must be grounded to the frame. Maybe rust behind it causing a break in the ground. Otherwise, check the voltage on that red wire with the horn button depressed, should be 12 volts or close. (one lead on the red wire, one on a good ground connection. Meter on DC volts). To check the horn switch put your meter on ohms and see if there's continuity across it when depressed.
Old Jan 29, 2011 | 07:35 PM
hatchetman's Avatar
hatchetman
If you have power going to it & it won't bark, hit it with a hammer a few times. If it's junk, use a car alarm siren. Those things are loud!!!
Hatch.
Old Jan 29, 2011 | 07:52 PM
RidemyEVO's Avatar
RidemyEVO
Not sure on our bike horns but I know on an automobile horn there is a screw that some times has to be adjusted to get a good honk out of it.
Old Feb 6, 2011 | 11:04 PM
V2Evo96's Avatar
V2Evo96
In 2003 I had to pull mine off and tapped it hard with a rubber mallet to break the "rusticles" out of it, then adjusted the tone with the built in screw.
Has worked ever since with no further intervention....
Old Feb 7, 2011 | 11:20 PM
#1rocketman's Avatar
#1rocketman
YEP,all good answers...and it might be in your horn switch,,,if you ever had your controls off ,there might be a loose wire in there,mine did that once. If it's junk,there should be lots of guys on here or ebay that's switched to some custom application or air horns,oughta be able to buy 1 for around $5 bucks .....good idea to get it workin though!
Old Feb 8, 2011 | 07:47 AM
grbrown's Avatar
grbrown
The ground on my bike is a thin braided cable, like a tiny auto ground cable. If yours is like that it could have corroded through. If you have a ground cable check it is fitted right! The horn is rubber mounted and the ground must go from the horn side, making a good contact with the horn, to the frame.
I just splashed out on a fancy chrome Mini Beast 2 air horn.....
DamifIknow
Aug 3, 2022 10:41 PM
busterman2
EVO
23
Dec 6, 2014 08:40 PM
Red 62
Electrical/Lighting/Alarm
Aug 7, 2014 07:56 PM
1harley 1vette
Jan 14, 2014 02:32 PM
Fossil
Apr 2, 2011 03:13 AM
