Horn Problem
Old Apr 1, 2011 | 07:18 PM
Fossil's Avatar
Fossil
Default Horn Problem
I have a 1988 FLHS that has had a horn problem for 10 years. Now and then when I pushed the horn button it would only make an audible 'thump' sound and not a horn blowing. To condense down what I have been doing I lengthened the power wire to the horn and replaced the wire crimp on connection. Then I have found the ground wire rusted in half and replaced it with a like type of ground wire. Each time the horn would work normally. Then I had to replace the grouind againg but this time I used an aircraft quality heavy futy wire with welded ends and that fixed it again. Now I have replaced the horn itself. No luck so where should I look now? Rerun the ground wire? How many volts does the horn get when the button is pushed? I want to put this decade long aggravation to rest so HELP!!
Old Apr 1, 2011 | 08:08 PM
lo-rider's Avatar
lo-rider
Originally Posted by Fossil
I have a 1988 FLHS that has had a horn problem for 10 years...HELP!!
After 10 years, I'd blame the mechanic. Sorry, couldn't resist.
If you've replaced ALL wiring and the horn, the only thing left is the switch, unless there is/should be a relay. Service manual will have a wiring diagram, in case somebody's messed it up. Check polarity.
Old Apr 1, 2011 | 08:11 PM
DaddyKnuck's Avatar
DaddyKnuck
Did you check the relay? That would be my guess, a bad connection on the trigger side.
Old Apr 1, 2011 | 08:22 PM
El Rey's Avatar
El Rey
If you over tighten the horn on the mount, it will effect the sound.
Old Apr 1, 2011 | 10:15 PM
oct1949's Avatar
oct1949
Me thinks its the honker not the wirer...
check the freak-en horn out
Old Apr 2, 2011 | 12:42 AM
Bluehighways's Avatar
Bluehighways
Purchase one of those Bumper Stickers that says; "Horn Broke, Watch for Finger."
Old Apr 2, 2011 | 02:11 AM
SteveO-ll's Avatar
SteveO-ll
Yea, It will Suck instead of Blow
Old Apr 2, 2011 | 03:13 AM
Khorgan's Avatar
Khorgan
LOL!!!!
My dad and I just bought some louder horns for our bikes. He really wanted a louder one. Not even sure I've even used mine, but I got one too. I Just rev my engine. Sense I got louder pipes, never really felt the need to honk.
DamifIknow
Aug 3, 2022 10:41 PM
lmz5150
EVO
Mar 28, 2019 08:29 AM
Gbishop303
Apr 12, 2017 06:09 PM
SportyPig
May 17, 2008 05:22 PM
Jinxie
EVO
Sep 1, 2007 11:45 PM
