Unknown squael
Old Feb 8, 2011 | 08:31 PM
calabera's Avatar
calabera
Default Unknown squael
I am new to the forum and the evos. I have a 95 heritage that is all stock with 10k miles on it and the problem im having is when i leave off the throttle there is a squealing noise but if i pull the clutch in it stops any ideas
Old Feb 9, 2011 | 01:13 AM
1997bagger's Avatar
1997bagger
2 things come to mind, check that drive belt tension or try and locate the sound and see if it is coming from the primary, the clutch can bark or squeel. Cleaning the drive belt and setting the tension can sometimes repair a belt noise and changing primary fluid (atf) can help with the clutch.
You also need to ride it more to prevent garage rot from settling in
Old Feb 9, 2011 | 02:31 PM
Brettfullthrottle's Avatar
Brettfullthrottle
I have to agree with 97BAGGER-the first thing I thought of was belt squeel-VERY common.
Old Feb 10, 2011 | 07:35 AM
nibroc's Avatar
nibroc
chrome pulleys will do it too!!!!
Old Feb 10, 2011 | 06:27 PM
calabera's Avatar
calabera
Its all stock except for V & H straight shots, i am going to check the belt . i traded a 02 fatboy for the heritage and love it, much more fun too ride than the tc.
thanks for the info
Old Feb 10, 2011 | 11:53 PM
hatchetman's Avatar
hatchetman
Rub a dry soap bar on both sides of your belt. No more squeal.
Hatch.
Acome
EVO
Jun 19, 2018 02:28 PM
waynemags
Custom Models
Jun 14, 2010 04:57 PM
wild_ivan242
Apr 23, 2010 10:09 PM
marksfatboy
Jun 9, 2008 04:06 PM
dope_man_21
Custom Models
Mar 8, 2008 10:22 AM
