Fuel Gauge Challenge!
I have bought a modern fuel level sender, hoping it will work with the fuel gauge on my bike. It has the part # 75281-08 moulded into it. The good news is it does work (outside the tank, I haven't tried it fitted inside yet), but only lifts the needle just above the red zone on my fuel gauge, when the sender float is in the 'full' position. The needle responds to moving the float arm up and down, but not across the whole width of the gauge.
So do any of our experts have any ideas? I suspect there is some electrical difference between my Evo gauge and later bikes, but can anyone suggest how I might persuade the needle to register 'full' on my gauge? If I can crack this my cup of joy will overflow!
There will be cake and coffee for the winning suggestion!
Get a variable resistor (pot) from wherever, even a speaker fader switch will work... It will need to be a value in the range of the gauge, i.e. 0-250 (or more) ohms. Tap the center lead of the pot and one of the outer leads. Place that across ground (earth) and the post of the sender. Keep in mind that if you're doing all this "on the bench" the sender must be grounded to the same source as the gauge. If it's already on the bike, then across any earth source and to the post of the sender...
Adjust the variable resistor until the readings on the gauge coincide with the float level position. At this point you can remove the pot and using an ohm meter, take a reading off the same two leads you used. That reading will be value of resistor you can permanently install as a bridge, as Hess suggested and it can be installed anywhere along the circuit of the fuel gauge sender wire as to make a hidden or neat job.
Adding resistance in-line would be backward to what he needs to get a closer to correct reading. My suggestion was to add a resistor across the line (wire from gauge) to ground. This has the effect of sending a signal of less resistance to the gauge. Obviously if you ground the signal wire coming from the gauge, it'd peg-out. So adding "some" extra grounding via a resistor would make it read higher.
Here's an example of a mod I've done before - if you add a 50 ohm resistor, connected to ground (that's earth to you Graham)
with the other end connected to the wire at the oil temp sender on 80's - early 90's era Evos with VDO gauges, it will raise the reading on the temp gauge by about 40-60 degrees. Now, that mod won't work for oil pressure, because that VDO gauge/sender works backward of the fuel or oil temp gauges. With oil pressure, you'd have to add resistance in-line to make it read higher.
1/Rtotal=1/R1+1/R2+1/R3...
