Carb adjusting
Old Mar 23, 2011 | 03:21 PM
RidemyEVO's Avatar
RidemyEVO
Originally Posted by miacycles
Carefully turn the plastic inner ****/nut (it's the little black ring behind the enrichner ****), this will tighten the housing around the cable and if it isn't worn out it will keep the enrichner out. That plastic nut is easy to break so only turn it a little at a time.
I broke a plastic nut last year and my buddy gave me another one, I don't have much confidence in the palstic nut. Can the plastic one be replaced with a metal nut or is there a reason they used plastic?
Old Mar 24, 2011 | 05:18 PM
bucaman's Avatar
bucaman
Default Update
I am still dealing with it not taking a quick throttle but that really looks like an accelarator pump issue. Getting a really weak shot of fuel. Not the good stream I would expect to see. I am assuming a clog to clean. Could also be in the linkage. If I turn the lever by hand I get a much better delivery.
Out on the road the bike pulls great thru the gears put tops out at 80mph. Not breaking up but does not want to give me anything more. Reading many things but getting mixed signals.
Am I rich or lean?
The 45 and 165 are still in put I plan to work thru some of the suggestions Sat. when I get back at it.
Old Mar 25, 2011 | 06:25 PM
miacycles's Avatar
miacycles
if it tops out at 80 mph, make sure you are getting full throttle and that the slide is moving freely.
Old Apr 2, 2011 | 04:53 PM
bucaman's Avatar
bucaman
Default Final Update
I ended up using a 46 and 180 and she is running great.
I did have to replace the accelerator pump diaphram. Cheap one in the rebuild kit was junk. Chinese I assume.
Anyway thanks to all for your suggestions and insights.
Bucaman
Old Apr 3, 2011 | 12:33 AM
Spanners39's Avatar
Spanners39
I would try 48/190 and see if that makes it even nicer. I run 48/200 and it pulls hard to the rev limiter and the gas mileage is still the same as when it was 45/175.
Old Apr 3, 2011 | 09:25 AM
perpulreaper's Avatar
perpulreaper
Does it still top out at 80 or are you getting more now
Old Apr 3, 2011 | 12:15 PM
bucaman's Avatar
bucaman
No, I think I'm good to go. I did readjust the float also. Still have to fine tune it. Shut it down at about 95 yesterday.
raymint
EVO
13
Jul 16, 2017 02:54 PM
Dago1
Mar 29, 2015 10:25 AM
XL1250
Jul 21, 2012 06:17 AM
Neal Perez
Ironhead
87
Feb 8, 2011 06:08 PM
lucospock
Feb 27, 2006 11:08 AM
